Fastlane
Holden Forums
Holden General Discussion
Holden Rodeo - How do I increase my Speed?
I have a Holden Rodeo 1999 Dual Cab 4 Wheel Drive Utility and I want to increase my top speed.
At the moment I can only get 135 Km/Hr and I KNOW THAT IT IS ILLEGAL, but I want to do it for a specific purpose which is LEGAL.
Has anyone attempted this before and can help me, if NOT has anyone got any idea how to do it? _________________ "COMMON SENSE": The biggest PROBLEM with "COMMON SENSE" now days is that it is just NOT USED OFTEN ENOUGH!!!!!
COMMON SENSE: The biggest problem with "COMMON SENSE" now days is that it is just NOT USED OFTEN ENOUGH!! |
Get a taller diff ratio. Most commercials have a ratio of about 4:1 for getting off the mark with a heavy load, but when your on the highway the revs are up, even in 5th. Get a different centre with say a 3:1 ratio, if your not carrying heavy stuff it sho |
You only have to be in front at the end of the race. |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
Re Legal Purpose - I am not prepared to divulge that information at this stage.
TURBO TURBO TURBO TURBO TURBO !!!!!!!! go hard or go home
On The Other Hand There's Finger's |
On The Other Hand Theres Fingers |
You could also improve the aerodynamics, with front splitter, side skirts, under body tray, laying the tailgate down, shaving the door handles, removing wiper arms etc.
James
You only have to |
quote: Originally posted by JBM
You could also improve the aerodynamics, with front splitter, side skirts, under body tray, la |
On The Other Hand There's Fi |
On The Other Hand Theres Fin |
Get a taller diff ratio. Most commercials have a ratio of about 4:1 for getting off the mark w |
Trade it in on a V6 Navara. 195kw.
Most powerfull ute in it class.
And no I dont own a Navara I own a Rodaygo as well. An 06 Dual cab.
And no I don't own a Navara I own a Rodaygo as well. An 06 Dual cab.
JBM laying the tail gate down or removing it was proven on the mythbuster to increas drag and use more fuel, it was an intresting show. The best otions where to leave the tail gate up as it forms a "bubble" of air in the back stream lining the air flow ov |
"Such is life" |
You have been a member since:: 28/04/2005(UTC) Posts: 758
OK 1999 had the V6 and the Turbo diesel. I have had two of these beasts. The turbos were gr8. Earlier ones had better gearing that 2000 plus series.
Now as you get above 135 km/h. It must be the V6. These suckers are over 5metres long, and sit high up.
Thanks for the comments. The Rodeo is a 2.8L Turbo Diesel and it does not scream.
I gather that the current gearing is low enough in 1st & 2nd gear which gets you in motion reasonably well and if the diff ratio was changed the only problem may be when |
Starting off in 4x4 on tar is the worst thing for your transfer case you will rip the guts out of it.
You have got me I can not for the life of me figure why you would want to make a torbo diesel exceed 135k's? Its not for burn outs, it not for drag ra |
"Such is life" |
You have got me I can not for the life of me figure why you would want to make a torbo diesel exceed 135ks? Its not for burn outs, it not for drag rac |
"Such is life" |
Is there some kind of guvaner (cant spell?) that it dosn't screem and most diesel you can turn up the fuel and push more in (more fuel = more power),thats what i did with an early Jackaroo till it got a V8 implant then the fun started .
He who dies wit |
He who dies with the most toys wins! |
Is there some kind of guvaner (cant spell?) that it dosnt screem and most diesel you can turn up the fuel and push more in (more fuel = more power),thats what i did with an early Jackaroo till it got a V8 implant then the fun started .
He who dies with |
Fastlane
Holden Forums
