#1 Posted : Saturday, 16 February 2008 9:02:38 PM(UTC)
I nothing ive tried has worked.
If you guys would just give me advice on what to try id really appreciate it.
Ive put his leads on another car and seemed fine .
replaced spark plugs with new ones.
Done compression test and all very close in kpa.
Done points and condensor.
tried my rotor from xw and my cap from xw.
Tried a coil from mk5 cortina. I think they are the same but not positive.
Ive taken fuel line off and pumped petrol into a bottle and looks clean and seems to pump fine.
I took the needle and seat out and they are all steel not like the rubber ones u get today but there is a round ring where it seats.
I blew through it and it appears to work but unsure once its in the car.
When I have air cleaner off and push accelerator pedal the carb squirts but the part it hits when squirting makes it spray out the top a bit, not sure if thats right.
Simptoms it sounds like its running on 3 cylinders and its poping and farting and black smoke pouring out the back.
After taking the dizzy out ummm its worse opps what have I done lol.
As many pointers as you can think off would be great as im all out of ideas.
Cheers in advance
Browno Offline
#2 Posted : Saturday, 16 February 2008 9:49:41 PM(UTC)
Browno
did u check the timing
Drive It Like You Stole It......Drive it like you own it
#3 Posted : Sunday, 17 February 2008 2:14:48 AM(UTC)
I statically timed it as it was running so crap that I dont think i could get it right
#4 Posted : Sunday, 17 February 2008 2:29:23 AM(UTC)
I mean I statically timed it. Before that I tried with timing light but it was running so crap that I dont think I could get it right
Browno Offline
#5 Posted : Sunday, 17 February 2008 3:35:34 AM(UTC)
Browno
im no expert but all i can think of is you may have put the dizzy in incorrectly. so say cylinder 6 is on the exhuast stroke and the spark plug sparks as this is commencing and on another cyclinder it way be sparking as the cyclinder is on its inlet strok
landy351 Offline
#6 Posted : Sunday, 17 February 2008 7:27:06 AM(UTC)
landy351
Check for vaccum leaks also check to see if inlet manifold has become loose also check vacuum diaphram on brake master cylinder
Mike
#7 Posted : Sunday, 17 February 2008 4:00:00 PM(UTC)
I think you may be right. ive been reserching putting distributor back in and. What I done was put it in while on compression stroke then turned the disstributor while key is on until it sparked. But one thing I didnt do was check which way it was facing
#8 Posted : Sunday, 17 February 2008 8:32:20 PM(UTC)
Remove plug 1 and jam dunny paper in the plug hole, slowly bump the engine on the starter until the paper goes POP and shoots out, That will give you rough enough to TDC ignition stroke on cylinder 1. Wack the dizzy in with the rotor button facing cylinde
#9 Posted : Sunday, 17 February 2008 8:36:30 PM(UTC)
Oops, when I say start wacking them on I mean the plug leads,Follow this method and your 4.1 will definately gain up to 400HP and have E.Ts of around 9 seconds.
(note... to reach 9 second quarters,said car must be pushed off a cliff)
#10 Posted : Monday, 18 February 2008 6:18:11 AM(UTC)
Hehe Doc nice :).
I did as above and on bits ive read here. I put a piece of hose with a plastic back tapped around it into the number 1 plug hole.
I turned motor over till plasic bag inflated. I then went to the TDC from the harmonic ballancer. I the
#11 Posted : Monday, 18 February 2008 6:26:32 AM(UTC)
landy351
I just went out in the dark to check what you said about vacume leakes and turns out 3 problems were found. I cant say when 2 of them occured
First leak the hose from the inlet manifold to the brake booster wasnt connected although I cant say i
Paul351xb Offline
#12 Posted : Monday, 18 February 2008 6:29:07 AM(UTC)
Paul351xb
Could it be the dizzy itself stuffed? Or worse case senario. Could the timing chain have jumped? When did the car stop working and what was the engine doing when this happened?
#13 Posted : Monday, 18 February 2008 7:17:44 AM(UTC)
check ya points gap, forget about ya balancer marks, they all LIE. Never seen a chain jump a tooth in my life. Im old btw. Belts yep, chains nope. Just jam dunny paper and crank til it pops, slap ya leads on and line number 1 up closest to ya rotor button
Paul351xb Offline
#14 Posted : Monday, 18 February 2008 1:17:40 PM(UTC)
Paul351xb
I've not seen the 6 jump a chain but I have seen a clevo jump a chain. The engine was old and the chain was stretched though. What sort of symptoms would a stuck valve give?
#15 Posted : Monday, 18 February 2008 4:24:25 PM(UTC)
Ummm. black smoke from unburnt fuel,a "wet" plug.Usually they will still start but run rough and maybe backfire a bit. Might be worth pullin the plugs for a looksee.Not sure if you have said weather or not the car was running ok before whatever happened t
#16 Posted : Monday, 18 February 2008 6:58:16 PM(UTC)
The boy just turned up home with it running like crap. Im not sure if he played with it before that, my guess is it happened then he may have played.
I new cam chain was fitted 6 months ago by him when he and me did the cam. He put the chain on etc so c
#17 Posted : Monday, 18 February 2008 7:08:04 PM(UTC)
I did try another dizzy but now im wondering if I had it in right at that time.
I got hold of a spare whole engine from a 1979 XD ute and its got a Electronic Distrubuter on it. It has 2 wires comming from it unlike the orginal which has only 1 from the
#18 Posted : Tuesday, 19 February 2008 4:08:01 AM(UTC)
I blocked the pipe that goes to the brake booster with a plastic bag and tape.
I blocked the other vacume pipe on the inlet manifold and last night I tightened the inlet manifold.
Tried to start the car but no luck. It fires but wont go.
I asked th
#19 Posted : Tuesday, 19 February 2008 4:28:07 AM(UTC)
Where ya live bloke ?
#20 Posted : Tuesday, 19 February 2008 4:23:09 PM(UTC)
Nn .. we are going to now bench start the other engine thats spare. And if it goes throw it in.
I give up lol.
Its got fuel its got spark what more does it want.
I tried his dizzy in another car and it works.
I will try the carb thats on his can on
Guest (7)
This page was generated in 0.097 seconds.
