meecar Offline
#1 Posted : Monday, 18 February 2008 9:28:57 PM(UTC)
meecar
howdy
just wondering with the vn-vp-v6 conversion into vk, i know the vn-vp K frame fits but i want to know if the v6 would fit if i left the vk K frame in.
and any other info about v6 conversion would be great.
#2 Posted : Monday, 18 February 2008 9:50:18 PM(UTC)
Hi meecar.
The engine mounts are totally different & you will also need the VN steering rack to clear the exhaust system on the drivers side.
Its easier to fit the whole K-member, including the steering rack, when doing the V6 conversion.
#3 Posted : Monday, 18 February 2008 9:50:18 PM(UTC)
Hi meecar.
The engine mounts are totally different & you will also need the VN steering rack to clear the exhaust system on the driver's side.
It's easier to fit the whole K-member, including the steering rack, when doing the V6 conversion.
Dr T
#4 Posted : Monday, 18 February 2008 11:48:18 PM(UTC)
http://www.fastlane.com....topic.asp?TOPIC_ID=15201
Some people say I am out of shape but they are wrong.....Round is a shape.
#5 Posted : Monday, 18 February 2008 11:48:18 PM(UTC)
#6 Posted : Tuesday, 19 February 2008 12:44:25 AM(UTC)
Hi Jim5.0
You mentioned in the other post that the VN K-member or compressor would not fit the VK.
AFAIK all VB to VP K-members will interchange & VN compressor clearance is not an issue. The VR/VS K-member will also fit the earlier cars, but there are then dramas with the castor angle.
Ive been involved in several of these conversions & its amazing what is interchangeable.
Dr Terry.
Edited by user Tuesday, 19 February 2008 12:58:00 AM(UTC)  | Reason: Not specified
#7 Posted : Tuesday, 19 February 2008 12:44:25 AM(UTC)
Hi Jim5.0
#8 Posted : Tuesday, 19 February 2008 10:34:10 PM(UTC)
Hello Dr Terry,
You misunderstood me I said that if you fit the V6 onto the VK K member you will not be able to use the A/C compressor <as it will hit the left engine mount>.
All I was trying to say was that if he chose to stay with the V
#9 Posted : Tuesday, 19 February 2008 10:34:10 PM(UTC)
Hello Dr Terry,
All I was trying to say was that if he chose to stay with the VK cross member it would cost him a lot more money than using the VN-VS K member.
The confusion probably comes from the fact that I said that you cannot use the VN gearbox cross member in the VK body < because where it bolts to the body are two different heights>
The beauty of owning any Commodore is that they are built like Meccano sets with lots of different holes for different options.
meecar Offline
#10 Posted : Thursday, 21 February 2008 2:14:18 AM(UTC)
meecar
hey thanks for that
1 other question, how would i go with the wiring because my vk is carby not injected if any one has info it would be great or even a diagram
meecar Offline
#11 Posted : Thursday, 21 February 2008 2:14:18 AM(UTC)
meecar
hey thanks for that
boom Offline
#12 Posted: : Thursday, 21 February 2008 2:21:51 AM(UTC)
boom
get the loom from the V6 car. best get a donor car. smashed VNs can be had for less than $500, and will have absolutely everything you need, except for the gearbox crossmember, and the tailshaft to suit.
Both of which shouldn't cost more than $300.
http
boom Offline
#13 Posted : Thursday, 21 February 2008 2:21:51 AM(UTC)
boom
Both of which shouldnt cost more than $300.
http://forum.streetcommo...showthread.php?t=8432752
Omicron Offline
#14 Posted : Thursday, 17 December 2009 3:58:56 AM(UTC)
Omicron
Does this mean that I can use a VK K-Frame to replace the bent K-Frame in my VP?
Or should I get a K-Frame from another VP to save any dramas?
#15 Posted : Thursday, 17 December 2009 7:12:59 AM(UTC)
Any V6 VN to VS K frame should do the trick. VK one has the red/blue/black engine mounts.
This is of course if your VP is a V6 engined car.
If at first you dont succeed then skydiving is not for you.
