bambino Offline
#1 Posted : Tuesday, 19 February 2008 4:17:42 AM(UTC)
bambino
Just rebuilt a red 253 got it all back in OK started first hit but it won't pick up the oil (new pump) drive is definitely engaged and I tried priming it with an oil can down the pressure guage hole, got a very limited amount in that way,filled the filter ('though you lose half of that putting the filter back on) Has anyone else had this problem or know of a remedy? (Yes the sump is full)
Mechatron Offline
#2 Posted : Tuesday, 19 February 2008 4:23:09 AM(UTC)
Mechatron
pack the pump with a lightweight grease, prolly 2 late for you now. I think you can spin the pump with a drill (in reverse?) and an old dizzy shaft like you can with a chev??
#3 Posted : Tuesday, 19 February 2008 4:50:45 AM(UTC)
As Mechatron says, use Vaseline or grease inside the pump, and fill the filter with oil. But you've probably already killed the bearings and cam, unless it only ran for a few seconds.
If we all h
#4 Posted : Tuesday, 19 February 2008 4:50:45 AM(UTC)
As Mechatron says, use Vaseline or grease inside the pump, and fill the filter with oil. But youve probably already killed the bearings and cam, unless it only ran for a few seconds.
If we all ha
bambino Offline
#5 Posted : Tuesday, 19 February 2008 5:39:34 AM(UTC)
bambino
Yeah the grease worked straight away. Ran for four goes at about a minute each time before I got enough sense to ask for help. The motor was assembled using copious amounts of moly-graphite engine assembly lube on the bearings and cam so I'll just have to
bambino Offline
#6 Posted : Tuesday, 19 February 2008 5:39:34 AM(UTC)
bambino
Yeah the grease worked straight away. Ran for four goes at about a minute each time before I got enough sense to ask for help. The motor was assembled using copious amounts of moly-graphite engine assembly lube on the bearings and cam so Ill just have to
trubluhq Offline
#7 Posted : Tuesday, 19 February 2008 8:39:50 AM(UTC)
trubluhq
Well done for priming via the oil sender hole !!
A few things at this point.
(!) Did the pump come off the block at any time ? Did the gear get put back in ?
(2) Did the shaft from the camshaft actually engage the oil pump spline ?
(3) Oid t
