bambino Offline
#1 Posted : Tuesday, 19 February 2008 4:17:42 AM(UTC)
bambino
Just rebuilt a red 253 got it all back in OK started first hit but it won't pick up the oil (new pump) drive is definitely engaged and I tried priming it with an oil can down the pressure guage hole, got a very limited amount in that way,filled the filter ('though you lose half of that putting the filter back on) Has anyone else had this problem or know of a remedy? (Yes the sump is full)
Mechatron Offline
#2 Posted : Tuesday, 19 February 2008 4:23:09 AM(UTC)
Mechatron
pack the pump with a lightweight grease, prolly 2 late for you now. I think you can spin the pump with a drill (in reverse?) and an old dizzy shaft like you can with a chev??
#3 Posted : Tuesday, 19 February 2008 4:50:45 AM(UTC)
Was thanked: 612 time(s) in 579 post(s)
As Mechatron says, use Vaseline or grease inside the pump, and fill the filter with oil. But you've probably already killed the bearings and cam, unless it only ran for a few seconds.
If we all h
#4 Posted : Tuesday, 19 February 2008 4:50:45 AM(UTC)
As Mechatron says, use Vaseline or grease inside the pump, and fill the filter with oil. But youve probably already killed the bearings and cam, unless it only ran for a few seconds.
If we all ha
bambino Offline
#5 Posted : Tuesday, 19 February 2008 5:39:34 AM(UTC)
bambino
Yeah the grease worked straight away. Ran for four goes at about a minute each time before I got enough sense to ask for help. The motor was assembled using copious amounts of moly-graphite engine assembly lube on the bearings and cam so I'll just have to
bambino Offline
#6 Posted : Tuesday, 19 February 2008 5:39:34 AM(UTC)
bambino
Yeah the grease worked straight away. Ran for four goes at about a minute each time before I got enough sense to ask for help. The motor was assembled using copious amounts of moly-graphite engine assembly lube on the bearings and cam so Ill just have to
trubluhq Offline
#7 Posted : Tuesday, 19 February 2008 8:39:50 AM(UTC)
trubluhq
Well done for priming via the oil sender hole !!
A few things at this point.
(!) Did the pump come off the block at any time ? Did the gear get put back in ?
(2) Did the shaft from the camshaft actually engage the oil pump spline ?
(3) Oid t
