#1 Posted : Thursday, 21 February 2008 1:17:02 AM(UTC)
when fitting double valve springs to 308 or 253 do the heads need machining or other mods ?
vintageholden Offline
#2 Posted : Thursday, 21 February 2008 2:11:14 AM(UTC)
vintageholden
no
just makes the valves stop bouncing
and return quicker
boom Offline
#3 Posted : Thursday, 21 February 2008 2:26:24 AM(UTC)
boom
and they are alot stronger than singles.
boom Offline
#4 Posted : Thursday, 21 February 2008 2:26:24 AM(UTC)
boom
Davesmonaro68 Offline
#5 Posted : Thursday, 21 February 2008 4:05:53 AM(UTC)
Davesmonaro68
The spring pads will need to be machined to suit the new springs if you want the job done proberly
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
adam PERTH Offline
#6 Posted : Thursday, 21 February 2008 9:56:36 AM(UTC)
adam PERTH
your valve springs should be matched to your cam, very important.
A1 Bogan.
trubluhq Offline
#7 Posted : Thursday, 21 February 2008 7:58:49 PM(UTC)
trubluhq
If you are doing a bog standard motor you wont need them. High performance race stuff would work well for a 308 yes, not worth it on a 253. Check with your workshop and see if its not overkill in $$$$ for you. You woudl prob need new seats too for the val
tanart Offline
#8 Posted : Thursday, 21 February 2008 8:55:31 PM(UTC)
tanart
Also some other advise is that if your installing a new cam make sure you run it in as per specs, especially if using double springs. If not then you could damage the cam lobes.
