XFDAZA Offline
#1 Posted : Saturday, 23 February 2008 3:42:37 AM(UTC)
XFDAZA
I have a noisy fan in my factory aircon XF. Think it might only be a leaf. Where does the fan hide and what is the best way to get to it.
Daza
#2 Posted : Thursday, 28 February 2008 9:45:58 AM(UTC)
Hello Daza,
I have never removed a fan from a XF, however, reading in my "factory" XF workshop manual the following is the first few steps:
1) Remove the glovebox
2) Remove the console.
3) Remove the instrument panel attaching screws and locate the
XFDAZA Offline
#3 Posted : Friday, 28 March 2008 10:58:15 AM(UTC)
XFDAZA
Thanks gts_hg, sounds nasty to get to the fan. I might have to see if it is just leaves by feeding something flexible like a hose or wire up and down the duct before removing the whole dash.
Has anyone got some experience with this.
DAZA
#4 Posted : Friday, 28 March 2008 11:55:44 PM(UTC)
Run the fan flat out and change from recirc to fresh a few times. If that fails you should be able to reach up behind the glovebox into the fan (whilst it is off of course) and remove the leaf.
Edited by user Friday, 28 March 2008 11:58:54 PM(UTC)  | Reason: Not specified
#5 Posted : Saturday, 29 March 2008 9:58:07 PM(UTC)
Thanks Daza for the update.
Regards,
gts_hg
basketcasebear Offline
#6 Posted : Sunday, 30 March 2008 8:46:09 AM(UTC)
basketcasebear
i have exactly the same prob, in my panelvan,, sounds more like a lump of 4x2 is in there??
will try the old, turn off and on while switching, recirc to fresh,, "trick!!! hope it vorks
bcb
ptpro
some men see things as they are, and ask "w
DOH!!!
XFDAZA Offline
#7 Posted : Sunday, 30 March 2008 8:47:30 PM(UTC)
XFDAZA
Problem solved. Thanks Jim5.0. The alternating did not help but putting my hand 200mm up the passenger floor output duct I could feel the fan. It’s actually a centrifugal blower. That is how accessible it was to my hand. What I found in there was not leav
#8 Posted : Wednesday, 2 April 2008 3:16:00 AM(UTC)
basketcasebear
well i tried the old turn the fan on off and turn dial around trick to no avail?
also tried putting my hand up passenger vent,, to no avail,,,
i just bought siad vehikkle, and definately have to have heater happening for winter, cause of MS,,, if it is
DOH!!!
Guest (9)
