2 Pages<12
#21 Posted : Monday, 25 February 2008 5:42:07 AM(UTC)
If the figures you are talking about are serious youll kill clutches and probably gearboxes. A manual car with that much hp would be pretty scary.
If we all had the same (good) taste, who would b
#22 Posted : Monday, 25 February 2008 5:42:07 AM(UTC)
If the figures you are talking about are serious you'll kill clutches and probably gearboxes. A manual car with that much hp would be pretty scary.
boom Offline
#23 Posted : Monday, 25 February 2008 5:46:38 AM(UTC)
boom
yes i know. are there anyclutches availible that will hold that sort of power? doesn't really matter, as that is a couple of years away.
I'll go with whatever i can find for now.
If nissan motorsport is nismo, then doesn't that ma
Edited by user Monday, 25 February 2008 5:47:36 AM(UTC)  | Reason: Not specified
boom Offline
#24 Posted : Monday, 25 February 2008 5:46:38 AM(UTC)
boom
yes i know. are there anyclutches availible that will hold that sort of power? doesnt really matter, as that is a couple of years away.
Ill go with whatever i can find for now.
If nissan motorsport is nismo, then doesnt that make
#25 Posted : Monday, 25 February 2008 6:33:44 AM(UTC)
With my clutch, I got a 3400 lb diaphragm fitted to a standard pressure plate and got a heavy duty clutch plate. I believe higher pressure diaphrams are available. Most clutch specialist should be able to do this for you. If this doesn't handle the torque
#26 Posted : Monday, 25 February 2008 6:33:44 AM(UTC)
With my clutch, I got a 3400 lb diaphragm fitted to a standard pressure plate and got a heavy duty clutch plate. I believe higher pressure diaphrams are available. Most clutch specialist should be able to do this for you. If this doesnt handle the torque,
ozchevy Offline
#27 Posted : Monday, 25 February 2008 6:50:59 AM(UTC)
ozchevy
The only thing close to the HP specs your quoting that Ive seen is the C6 Callaway Corvette. Twin turbo, fuel injected, 5.7 ltr with 6 Speed manual trans. 880 HP.
With the turbos bolted on each side, the engine is wider than it is long, so I cant see
ozchevy Offline
#28 Posted : Monday, 25 February 2008 6:50:59 AM(UTC)
ozchevy
The only thing close to the HP specs your quoting that I've seen is the C6 Callaway Corvette. Twin turbo, fuel injected, 5.7 ltr with 6 Speed manual trans. 880 HP.
With the turbos bolted on each side, the engine is wider than it is long, so I can't se
boom Offline
#29 Posted : Monday, 25 February 2008 7:22:27 AM(UTC)
boom
no. 'just' a holden V8. stroker, forged rods and pistons, twin GT42 garrett ball bearing turbos. should make 900hp pretty easily. i can show a VN making more with smaller turbos if you like. street driven of course.
If nissan motor
boom Offline
#30 Posted : Monday, 25 February 2008 7:22:27 AM(UTC)
boom
no. just a holden V8. stroker, forged rods and pistons, twin GT42 garrett ball bearing turbos. should make 900hp pretty easily. i can show a VN making more with smaller turbos if you like. street driven of course.
If nissan motorsp
keithholden Offline
#31 Posted : Monday, 25 February 2008 5:47:47 PM(UTC)
keithholden
How reliable will it be? I know some engines become expensive grenades.
Like byron said Th400 is a good choice. You can burnout and the car changes gears all the way to top.
Cruisy to drive and strong. Manuals dropping the clutch breaks stuff more o
boom Offline
#32 Posted : Tuesday, 26 February 2008 2:08:35 AM(UTC)
boom
whatever, it's a while away.
boom Offline
#33 Posted : Tuesday, 26 February 2008 2:08:35 AM(UTC)
boom
whatever, its a while away.
2 Pages<12
This page was generated in 0.105 seconds.
