BAD WB Offline
#1 Posted : Tuesday, 26 February 2008 8:12:58 AM(UTC)
BAD WB
I am thinking about replacing my 308 with a 350 with the intent to stroke it to a 383, aside from the weight factor was wandering what the pro's and cons are between Ali and cast blocks and heads?
#2 Posted : Tuesday, 26 February 2008 4:23:14 PM(UTC)
Before you do it, look into ADR's with a Chev in a WB. It would be easier in a WB to stroke your 308 to 350 or 377, assuming you already have tough gearbox and diff. Look here: http://www.comeracing.com/
The 350 and 377 kits are less than $2200. Just nee
#3 Posted : Tuesday, 26 February 2008 4:23:14 PM(UTC)
Before you do it, look into ADRs with a Chev in a WB. It would be easier in a WB to stroke your 308 to 350 or 377, assuming you already have tough gearbox and diff. Look here: http://www.comeracing.com/
The 350 and 377 kits are less than $2200. Just need
#4 Posted : Wednesday, 27 February 2008 6:11:07 AM(UTC)
there is a guy who does alot with the commodore chevs.i have heard he has imported a good number of 6ltrs with harness and computer and selling them for under 5K. pass emissions and all alloy and go really well.
boom Offline
#5 Posted : Wednesday, 27 February 2008 6:41:29 AM(UTC)
boom
yes holden stroker is a much cheaper option. eagle 355 stroker cranks can be had for $550, if its not a speed demon, then just chev X- rods ($10 each @ suburban imports) and some 350 chev pistons (cheap as chips, seals bearing, etc shouldn't cost too much
boom Offline
#6 Posted : Wednesday, 27 February 2008 6:41:29 AM(UTC)
boom
yes holden stroker is a much cheaper option. eagle 355 stroker cranks can be had for $550, if its not a speed demon, then just chev X- rods ($10 each @ suburban imports) and some 350 chev pistons (cheap as chips, seals bearing, etc shouldnt cost too much.
