boom Offline
#1 Posted : Saturday, 1 March 2008 2:12:30 AM(UTC)
boom
hi guys, if i'm running a 3.48" crank, and 5.7" chev rods on a 350 holden stroker, how do i work out the pin/compression height? this is assuming i have a zero deck height.
Alex
Edited by user Saturday, 1 March 2008 2:19:46 AM(UTC)  | Reason: Not specified
boom Offline
#2 Posted : Saturday, 1 March 2008 6:37:16 PM(UTC)
boom
bump
boom Offline
#3 Posted : Saturday, 1 March 2008 6:37:16 PM(UTC)
boom
bump
#4 Posted : Sunday, 2 March 2008 9:06:26 AM(UTC)
piston at bdc, volume from top of piston to deck face, divide by capacity of head cavity, eg, volume = 100cc, head cavity capacity 10cc, compression = 10:1
example only dont take literally.
#5 Posted : Sunday, 2 March 2008 9:06:26 AM(UTC)
example only don't take literally.
#6 Posted : Sunday, 2 March 2008 9:22:40 AM(UTC)
by the way when measuring the capacities dont use water the surface wont be dead flat. dont use petrol too dangerous and runs through too quick, use paraffin or kerosene they do not have the surface tension of kerosene. Although I have heard some detergen
#7 Posted : Sunday, 2 March 2008 9:22:40 AM(UTC)
by the way when measuring the capacities don't use water the surface won't be dead flat. don't use petrol too dangerous and runs through too quick, use paraffin or kerosene they do not have the surface tension of kerosene. Although I have heard some deter
boom Offline
#8 Posted : Sunday, 2 March 2008 10:10:01 AM(UTC)
boom
i'm looking for the pin height of the piston, not the comp ratio. thanks anyway though. if anyone can tell me the EXACT deck height of a VN-VT 304 block (i think it's 8.80" not too sure though).
Need to find out which piston to choose for a 355 stroker
boom Offline
#9 Posted : Sunday, 2 March 2008 10:10:01 AM(UTC)
boom
im looking for the pin height of the piston, not the comp ratio. thanks anyway though. if anyone can tell me the EXACT deck height of a VN-VT 304 block (i think its 8.80" not too sure though).
boom Offline
#10 Posted : Sunday, 2 March 2008 11:51:42 PM(UTC)
boom
dont worry, got it. for those interested, a 5.7" rod with a 3.48" crank needs a 1.425" pin height in a 308/304 block. This is a 383 piston. which makes it cheaper from the US. gotta love that exchange rate!
Edited by user Sunday, 2 March 2008 11:53:16 PM(UTC)  | Reason: Not specified
