#1 Posted : Saturday, 1 March 2008 9:31:17 AM(UTC)
what do resistor spark plugs do? Can you do without the suppressors and shielded plug leads with the resistor plugs? is there any real advantage to them?
ozchevy Offline
#2 Posted : Saturday, 1 March 2008 9:36:55 AM(UTC)
ozchevy
Never heard of them John,
At a guess, I would say you could probably use a straight copper core HT lead with them.
#3 Posted : Saturday, 1 March 2008 12:31:28 PM(UTC)
well googled it turns out resistor plugs have been around since the 60s, apparently they are necessary if you have computerised systems and/ or gps etc in your car, as cuts radio interference.
in older cars doesn't matter but does not give best performa
#4 Posted : Saturday, 1 March 2008 12:31:28 PM(UTC)
in older cars doesnt matter but does not give best performan
keithholden Offline
#5 Posted : Thursday, 6 March 2008 10:50:29 PM(UTC)
keithholden
My Eh has the old copper leads that it had when I purchased it 19yrs ago. They dont even have any rubber boots on them. Not sure if thats a factory part or not.
I only had to clean them once as they got corroded, that was after driving about 60000 Mile
hkpremier1968 Offline
#6 Posted : Thursday, 6 March 2008 11:15:40 PM(UTC)
hkpremier1968
Hi there, this is for ozchevy. The straight copper core HT leads where found the interfear with emgancy radios and have not been used for along time. Yes they are better with very low to no ohm reading at all. The Holden spec for ohm on the older cars was
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
#7 Posted : Friday, 7 March 2008 2:16:19 AM(UTC)
i read somwhere stainless steel cord leads are the best
