#1 Posted : Friday, 16 November 2007 9:25:51 AM(UTC)
hey guys um just wondering if any one knows im loooking at buyin a lh or lx torrie cant find one yet in perth... but yeh just wondering if anyone knows if its a big job changing the column shift to the flooor or would it just be better trying to find one with the transmission on the floor? cheers guys
#2 Posted : Friday, 16 November 2007 4:04:31 PM(UTC)
Was thanked: 601 time(s) in 568 post(s)
Easy conversion if it's an auto. Just get all the bits required off a T-bar car including a template for the floor hole. It's a bit harder if it's a manual as you'll also have to replace the 3-speed with a 4-speed, unless you want to stick an aftermarket
#3 Posted : Friday, 16 November 2007 4:04:31 PM(UTC)
Easy conversion if its an auto. Just get all the bits required off a T-bar car including a template for the floor hole. Its a bit harder if its a manual as youll also have to replace the 3-speed with a 4-speed, unless you want to stick an aftermarket shif
This page was generated in 0.119 seconds.
