hey guys um just wondering if any one knows im loooking at buyin a lh or lx torrie cant find one yet in perth... but yeh just wondering if anyone knows if its a big job changing the column shift to the flooor or would it just be better trying to find one with the transmission on the floor? cheers guys
Easy conversion if it's an auto. Just get all the bits required off a T-bar car including a template for the floor hole. It's a bit harder if it's a manual as you'll also have to replace the 3-speed with a 4-speed, unless you want to stick an aftermarket |
Easy conversion if its an auto. Just get all the bits required off a T-bar car including a template for the floor hole. Its a bit harder if its a manual as youll also have to replace the 3-speed with a 4-speed, unless you want to stick an aftermarket shif |
