Nighthalk Offline
#1 Posted : Wednesday, 5 March 2008 5:02:38 AM(UTC)
Nighthalk
Hey guys.
I have a 99 vt calias and i have a slight problem with the ignition
This only happened today when i was ready to leave work.
I turned the key and everything seemed fine until it turned over twice then died on me, so i tried again and there was nothing, took key out, then i noticed my ignition lights were still on but no key in the ignition??
Would this be just the barrel gone or is it more then that?
Ive got 2 keys for the car and neither will allow me to start the car.
Can turn keys all the way but seems lose
Can anyone help me out with this problem before i spend $$$ on tow + workshop only to find out i could of fixed myself.
Ive already been told i need to replace the whole thing not just the barrel which will cost me up to $500 ( told by a friend )
Thanks.
Edited by user Wednesday, 5 March 2008 5:23:17 AM(UTC)  | Reason: Not specified
hkpremier1968 Offline
#2 Posted : Wednesday, 5 March 2008 5:17:59 AM(UTC)
hkpremier1968
Hi mate,
the first thing I would do is undo the shroud to see if the back of the ignition has had the screw come out. It sounds like it has popped out then you where cranking it and thats why the reds where still on as it would have gone back to the run
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
#3 Posted : Wednesday, 5 March 2008 5:17:59 AM(UTC)
hkpremier1968
Hi mate,
the first thing I would do is undo the shroud to see if the back of the ignition has had the screw come out. It sounds like it has popped out then you where cranking it and that's why the reds where still on as it would have gone back to the ru
Nighthalk Offline
#4 Posted : Wednesday, 5 March 2008 5:29:13 AM(UTC)
Nighthalk
It looks all in good order cant see any problems from the out side
#5 Posted : Wednesday, 5 March 2008 5:40:40 AM(UTC)
hkpremier1968
You will not see anything wrong if you have not remover the column shroud to see the rear of the ignition switch. The other thing that could have happened is the plate at the back of the barrel itself could have snapped. You will need the undo the screw w
#6 Posted : Thursday, 6 March 2008 8:49:03 AM(UTC)
hkpremier1968
Hi, how did you go with your VT? Cheers.
HQ SAND MAN Offline
#7 Posted : Friday, 7 March 2008 7:33:12 AM(UTC)
HQ SAND MAN
You are a member of these groups:: Registered
Hey mate just as a thought it could be something too do with your steering lock , we had a car the other day that did the same thing , eg turned the key and then it felt like the barrel went limp all the dash lights came on but would not start ,, ? is the
mmazz30 Offline
#8 Posted : Friday, 7 March 2008 7:47:51 AM(UTC)
mmazz30
The back of the ignition barrell has broken the cast alloy pin/rod that rotates the ignition switch...common.
You would have had the key getting slightly harder to turn and then not returning properly,also the steering lock would not lock as you removed
Edited by user Friday, 7 March 2008 7:49:06 AM(UTC)  | Reason: Not specified
Custom Offline
#9 Posted : Friday, 7 March 2008 6:10:55 PM(UTC)
Custom
Yep, gone are the days where a shifter, screw driver or pair of pliers would get you going, or help start anything worth starting for that matter.
#10 Posted : Friday, 7 March 2008 6:27:09 PM(UTC)
I agree with mmazz on this one. I've had to replace a few of these recently in VR & VS models, and VT use the same system.
The rough price for a new barrell, keyed to your existing key, is around $45 at a decent locksmith.
________
#11 Posted : Friday, 7 March 2008 6:27:09 PM(UTC)
I agree with mmazz on this one. Ive had to replace a few of these recently in VR & VS models, and VT use the same system.
_________
Nighthalk Offline
#12 Posted : Saturday, 8 March 2008 6:20:14 AM(UTC)
Nighthalk
mmazz30 Offline
#13 Posted : Saturday, 8 March 2008 7:28:12 AM(UTC)
mmazz30
Good to hear Nighthawk as i'm attached to my left knacker :-)
I had the same thing happen to me in my VT a couple of years ago,filled up with fuel and went to start it and bang.
I've also heard that whatever ignition barrels are left at the dealers is a
mmazz30 Offline
#14 Posted : Saturday, 8 March 2008 7:28:12 AM(UTC)
mmazz30
Good to hear Nighthawk as im attached to my left knacker :-)
Ive also heard that whatever ignition barrels are left at the dealers is all
