i put new bearings and oil seals on my banjo axles and new seats in my housing now their leaking just a bit but i need aquick fix for rego any ideas plus can one machine the axle housings at the seal end to reco them cheers
Hi john
What model ?
Dr Terry |
dr terry its a hq banjo diff cheers
when did cup and cone axel bearings finish? 72?
John, i normally put some permaseal on the axel flange gasket, (there should be a gasket there, but nowadays u rarely see them!)
A1 Bogan. |
Hi Guys.
Holden used ball bearing axle bearings from 48 (FX) up to HG & LJ. Timken tapered rear axle bearings were used up to VS (except IRS). They also used them is VY/VZ Crewman & One-Tonners.
The HQ used a tapered rear bearing.
Unless the axle |
