#1 Posted : Thursday, 6 March 2008 12:34:52 AM(UTC)
i put new bearings and oil seals on my banjo axles and new seats in my housing now their leaking just a bit but i need aquick fix for rego any ideas plus can one machine the axle housings at the seal end to reco them cheers
#2 Posted : Thursday, 6 March 2008 12:40:24 AM(UTC)
Hi john
What model ?
#3 Posted : Friday, 7 March 2008 1:51:34 AM(UTC)
dr terry its a hq banjo diff cheers
adam PERTH Offline
#4 Posted : Friday, 7 March 2008 2:34:07 AM(UTC)
adam PERTH
when did cup and cone axel bearings finish? 72?
John, i normally put some permaseal on the axel flange gasket, (there should be a gasket there, but nowadays u rarely see them!)
A1 Bogan.
#5 Posted : Friday, 7 March 2008 6:52:21 PM(UTC)
Hi Guys.
Holden used ball bearing axle bearings from 48 (FX) up to HG & LJ. Timken tapered rear axle bearings were used up to VS (except IRS). They also used them is VY/VZ Crewman & One-Tonners.
The HQ used a tapered rear bearing.
Unless the axle
