htprem350 Offline
#1 Posted : Thursday, 6 March 2008 9:47:06 PM(UTC)
htprem350
Hi again,
Does anyone have experience with fitting a Turbo 350 auto into a HT.
If so does the housing clear the transmisson tunnel ok and can you still use the original rear mounting crossmember.
The car was a six cyl so it hasn't got and larger tunnel like the v8 option.
Thanx guys
hkpremier1968 Offline
#2 Posted : Thursday, 6 March 2008 10:53:50 PM(UTC)
hkpremier1968
Hi mate, the tunnel on all HK HT HG's are the same size, the only change is the Saginaw cars had a bolge on the front of the left floor pan to fit the gear linkage. As for the TH350 I have seen them in HT's without a problem (TH400 do not fit). I would us
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
#3 Posted : Thursday, 6 March 2008 10:53:50 PM(UTC)
hkpremier1968
Hi mate, the tunnel on all HK HT HGs are the same size, the only change is the Saginaw cars had a bolge on the front of the left floor pan to fit the gear linkage. As for the TH350 I have seen them in HTs without a problem (TH400 do not fit). I would use
htprem350 Offline
#4 Posted : Thursday, 6 March 2008 11:11:42 PM(UTC)
htprem350
Thanks heaps mate,
I was not sure if the tunnels were all the same as there is a lot of heresay on the matter.
What is the deal with the step down crossmember, is it an original fitment and as you have one whats the price.
htprem350 Offline
#5 Posted : Thursday, 6 March 2008 11:11:42 PM(UTC)
htprem350
Thanks heaps mate,
What is the deal with the step down crossmember, is it an original fitment and as you have one what's the price.
#6 Posted : Thursday, 6 March 2008 11:20:53 PM(UTC)
hkpremier1968
Hi, I have one from a HT 307 powerglide Brougham. They have the plate where the mount bolts to lower than the 6cyl and the V8 tri-matic cars. I can send you a pic if you send me your email address. My email is [email protected]. Cheers.
htprem350 Offline
#7 Posted : Thursday, 6 March 2008 11:26:21 PM(UTC)
htprem350
#8 Posted : Thursday, 6 March 2008 11:28:33 PM(UTC)
hkpremier1968
Are you in Sydney? cheers.
htprem350 Offline
#9 Posted : Thursday, 6 March 2008 11:32:41 PM(UTC)
htprem350
No Perth mate
HG383PREM Offline
#10 Posted : Thursday, 6 March 2008 11:45:23 PM(UTC)
HG383PREM
The T350 will go straight in with crossmember mods (Z plate) as said above. The rear mount is forward and stepped down with the T350.
Shane
htprem350 Offline
#11 Posted : Thursday, 6 March 2008 11:49:21 PM(UTC)
htprem350
Thanx mate,
I will have to get me one of them.
#12 Posted : Friday, 7 March 2008 12:15:57 AM(UTC)
hkpremier1968
Hi, the HK is the only one that uses a Z plate as it has the gearbox cross member bolted to the floor not on a set of rails. Ht HG have a series of holes on there gearbox rails to fit lots of different gearboxes in. There where 3 speed 6&8, powerglide 6&8
#13 Posted : Friday, 7 March 2008 12:15:57 AM(UTC)
hkpremier1968
Hi, the HK is the only one that uses a 'Z' plate as it has the gearbox cross member bolted to the floor not on a set of rails. Ht HG have a series of holes on there gearbox rails to fit lots of different gearboxes in. There where 3 speed 6&8, powerglide 6
