Bat out of hell Offline
#1 Posted : Sunday, 9 March 2008 10:18:10 AM(UTC)
Bat out of hell
Heyy there.. i need sum help or advice in building up a 202 to put in a hr ute. i have no budget at this stage so any suggestions from mild to wild will be appreciated. 1st wat engine? ive herd of ppl using blue blocks with Red crank and a black head? any suggestions to do with that aswell as yella terra head. and wat carby's and cams to use will be very help full. Also it is 4 mainly high performance street with a little towing..
Any information will be great help.
Cheers blake
U Have to be young and dumb to be old and wise
Edited by user Sunday, 9 March 2008 10:27:05 AM(UTC)  | Reason: Not specified
boom Offline
#2 Posted : Sunday, 9 March 2008 10:26:08 AM(UTC)
boom
search for this in there:
youll get the answers you need. this has been covered more frequently and in depth than any other topic on the forum.
If nissan motorsport is nismo, then doesnt that make honda motorsport H
boom Offline
#3 Posted : Sunday, 9 March 2008 10:26:08 AM(UTC)
boom
you'll get the answers you need. this has been covered more frequently and in depth than any other topic on the forum.
If nissan motorsport is nismo, then doesn't that make honda motorsport
adam PERTH Offline
#4 Posted : Tuesday, 11 March 2008 9:02:17 AM(UTC)
adam PERTH
go for mild motor rather than a hottie.
A1 Bogan.
vintageholden Offline
#5 Posted : Tuesday, 11 March 2008 1:32:35 PM(UTC)
vintageholden
why mild
Cheers blake
he asked for performance
help him out
#6 Posted : Tuesday, 11 March 2008 11:15:15 PM(UTC)
Bat out of hell
ive just bought a blue 202 ive got the black 202 head at home aswell. i am going to rebuild the blue block and reconditoin the black head.wat type of rocker gear would be good for this set up my mate also has a double webber setup for his 186 that he no l
boom Offline
#7 Posted : Wednesday, 12 March 2008 4:22:45 AM(UTC)
boom
1. You can't put the twins on you black head.
2. Don't use the black head unless you are running injection.
3. Use a red head. saves a big headache, Yella Terras flow close to the black head, have a broader manifold choices, and they can be found for un
boom Offline
#8 Posted : Wednesday, 12 March 2008 4:22:45 AM(UTC)
boom
1. You cant put the twins on you black head.
2. Dont use the black head unless you are running injection.
3. Use a red head. saves a big headache, Yella Terras flow close to the black head, have a broader manifold choices, and they can be found for unde
#9 Posted : Wednesday, 12 March 2008 5:19:17 AM(UTC)
Bat out of hell
yea thats no problem as i said i have the black head a home but getting another head is no drama..ive allways wanted to build a red 202 with 186 head but evry 1 keeps sayin dont bother. ur better off going with a 12 port head. why is that? and ive got a c
boom Offline
#10 Posted : Wednesday, 12 March 2008 6:14:13 AM(UTC)
boom
the only difference is the rocker studs rather than bridges.
boom Offline
#11 Posted : Wednesday, 12 March 2008 6:14:13 AM(UTC)
boom
#12 Posted : Wednesday, 12 March 2008 11:28:08 AM(UTC)
whats wrong with using the black head? bigger valves and better porting. take 40thou off for around 10:1 compression and run premium at least.Although i agree with the manifold choices unless you go injection.
boom Offline
#13 Posted : Wednesday, 12 March 2008 11:53:39 AM(UTC)
boom
thats the only reason
boom Offline
#14 Posted : Wednesday, 12 March 2008 11:53:39 AM(UTC)
boom
HOLD ON Offline
#15 Posted : Wednesday, 12 March 2008 10:35:00 PM(UTC)
HOLD ON
anyone in perth have a black head for sale
adam PERTH Offline
#16 Posted : Wednesday, 12 March 2008 10:36:45 PM(UTC)
adam PERTH
Yep.
$80 for long motor.
0419934767
A1 Bogan.
Edited by user Wednesday, 12 March 2008 10:37:25 PM(UTC)  | Reason: Not specified
HOLD ON Offline
#17 Posted : Wednesday, 12 March 2008 10:39:01 PM(UTC)
HOLD ON
that was quick
i,ll call today
Guest (10)
