cheffy Offline
#1 Posted : Tuesday, 11 March 2008 11:03:22 PM(UTC)
cheffy
Looking at a couple of holden panel vans(SANDMAN) wanting to purchase one to restore to former glory, however I'm wanting to find out if they are genuine. I have the codes for both of them if someone could have a look at them to check if they are.
MODEL:HX8W M70, BODY: 223590-A, TRIM:1925-18V,PAINT:567-30183,ENG: L31, TRANS: M21,B/AXLE: GV4, HX PANEL VAN REG:01/77 AHX22617A,GVW:1950,SKINNY PLATE:8M70TGL371978X
SECOND CAR:HJ 10/74,L20,M21,GV78WM70, MODEL:HJ8WM70, BODY:131542-A,TRIM:1898-19V, PAINT:567-15944,ENG:L20,AXLE:GV7 3:55,1,GVM:2155,BUILD DATE:10/77,RAIL:AHJ02986A,SKINNY TAG:8WM70LEL291160J
IF SOMEONE IS ABLE TO HELP ME THAT WOULD BE GREATLY APPRECIATED.REGARDS CHEFFY
Absinth Offline
#2 Posted : Wednesday, 12 March 2008 1:34:28 AM(UTC)
Absinth
The HX is definately a Sandman having slate black trim and a 1950GVW. Sorry, I don't know the paint code.
The HJ is a good chance it is a Sandman with Deauville Blue Metallic paint, black trim and a 202 engine. Is it plated as a 2 seater, does it have
Absinth Offline
#3 Posted : Wednesday, 12 March 2008 1:34:28 AM(UTC)
Absinth
The HX is definately a Sandman having slate black trim and a 1950GVW. Sorry, I dont know the paint code.
The HJ is a good chance it is a Sandman with Deauville Blue Metallic paint, black trim and a 202 engine. Is it plated as a 2 seater, does it have a
cheffy Offline
#4 Posted : Wednesday, 12 March 2008 1:44:01 AM(UTC)
cheffy
Hi Absinth, yes the HJ is plated as a 2 seater, and it has a full headlining, not sure about the door switches. the motor was originally a 202 he said but has had a 253 put in which might explain the gearbox(what was the m21?)interesting to see the GVMis
cheffy Offline
#5 Posted : Wednesday, 12 March 2008 1:59:45 AM(UTC)
cheffy
Hi again, in regards to the paint code she said that it was originally a goldy colour if that means anything? 567-30183(code)Cheers.
Mr.Jones Offline
#6 Posted : Wednesday, 12 March 2008 2:50:19 AM(UTC)
Mr.Jones
Paint code 30183 is Persian Sand Met Mk2
Leroy
Voltaire
crowe Offline
#7 Posted : Wednesday, 12 March 2008 7:48:37 AM(UTC)
crowe
Guy's what do you think a late HZ sandman in restored/ mint condition, window less could be worth?
crowe Offline
#8 Posted : Wednesday, 12 March 2008 7:48:37 AM(UTC)
crowe
Guys what do you think a late HZ sandman in restored/ mint condition, window less could be worth?
cheffy Offline
#9 Posted : Wednesday, 12 March 2008 10:10:26 AM(UTC)
cheffy
You would probably be looking at around $30-35k, going on the ones that I have seen recently.
cheffy Offline
#10 Posted : Wednesday, 12 March 2008 11:24:10 AM(UTC)
cheffy
Hi absinth, Ive just rechecked my numbers I had for the HJ and noticed that the gearbox is in fact a m20, do you think that this one stands a good chance at being an original?
cheffy Offline
#11 Posted : Wednesday, 12 March 2008 11:24:10 AM(UTC)
cheffy
Hi absinth, I've just rechecked my numbers I had for the HJ and noticed that the gearbox is in fact a m20, do you think that this one stands a good chance at being an original?
#12 Posted : Wednesday, 12 March 2008 4:22:14 PM(UTC)
Was thanked: 612 time(s) in 579 post(s)
