#1 Posted : Thursday, 13 March 2008 5:57:45 AM(UTC)
hey ive just finished wiring up my 307 chev motor, i wasnt 100% with my dissy placing , but the thing starts and runs , just .... should be able to fine tune with a timing light. yes/no
just to confirm does someone know the cylinder numbers , my hk repair book showed 2 diagrams with complete opposite piston numbering , one with the 1st piston on the front left and the other on the front right.
and finally and most important , is there a good way i can tell if ive got some good oil pressure , i got the motor second hand and it has no oil through it , ive connected up my oil pressure light , and it stays on , but i was thinking maybe it takes some time to build up pressure. also took rocker cover off and no oil is showing.
although probably only run the car for prob 1 minute not even.
i want to fix this before mucking around with timing, as i dont want internal damage.
Sandman Offline
#2 Posted : Friday, 14 March 2008 5:25:16 AM(UTC)
Sandman
#1cyl is front left(Passenger side)
Get a master gauge to check oil pressure. Screw into hole behind intake manifold(near dissy).
If you put the dissy in, is it in properly, all the way til it touchs the block, as it drives the oil pump.
If you look a
