#1 Posted : Friday, 14 March 2008 10:26:45 AM(UTC)
hi can anyone help
i have a 202 head here that the serial numbers match that of the xu1 head- yet it was made in 71 - were they ever brought out that early ??
i also had another fella check the numbers and he said the numbers match but cant remember if they were brought out that year.
do the71 202 xu1 heads exist? or is it just a mistake
hkpremier1968 Offline
#2 Posted : Friday, 14 March 2008 10:34:04 AM(UTC)
hkpremier1968
Hi Kyle, I would check that the '1' on the date code is not a '2' as some date codes are hard to read on the heads cast iron. Just as a matter of interence what is the date code and where did you find it? Cheers.
Lots of cars, Lots of projects and Lots
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
#3 Posted : Friday, 14 March 2008 10:34:04 AM(UTC)
hkpremier1968
Hi Kyle, I would check that the 1 on the date code is not a 2 as some date codes are hard to read on the heads cast iron. Just as a matter of interence what is the date code and where did you find it? Cheers.
#4 Posted : Friday, 14 March 2008 10:42:18 AM(UTC)
e81 but ill check for sure in the morning- it was on the exhaust inlet side in the misddle
but ill check again in the morning
#5 Posted : Friday, 14 March 2008 7:11:45 PM(UTC)
hkpremier1968
Hi Kyle, the position sounds right. does the 1 look straight or bent? The 2 tooling could look like a 1 as it is a small number and if the two tails didnt cast right you never know. Cheers.
#6 Posted : Friday, 14 March 2008 7:11:45 PM(UTC)
hkpremier1968
Hi Kyle, the position sounds right. does the '1' look straight or bent? The '2' tooling could look like a '1' as it is a small number and if the two tails didn't cast right you never know. Cheers.
Davesmonaro68 Offline
#7 Posted : Friday, 14 March 2008 8:33:04 PM(UTC)
Davesmonaro68
Kyle could be LJ GTR not XU1
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#8 Posted : Friday, 14 March 2008 10:44:14 PM(UTC)
hi thanks all - anyway open to offers on it if anyones interested in it- no use to me but no doubt others may have need for it
#9 Posted : Monday, 17 March 2008 8:56:13 AM(UTC)
how can you be contacted Kyle?
you are not signed up
Dr Terry Online
#10 Posted : Monday, 17 March 2008 10:18:07 PM(UTC)
Hi Guys.
The same head casting was used for both LC & LJ XU-1s. Very early ones (1970) had no cast part number, but the head was still essentially the same.
If the casting date is before 6/71, it's probably off a 3100X engine. 6/71 to late 71 it's p
Dr Terry Online
#11 Posted : Monday, 17 March 2008 10:18:07 PM(UTC)
Hi Guys.
If the casting date is before 6/71, its probably off a 3100X engine. 6/71 to late 71 its pro
#12 Posted : Tuesday, 18 March 2008 6:38:26 AM(UTC)
Davesmonaro68
Kyle isnt that head no 2811930
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#13 Posted : Tuesday, 18 March 2008 6:38:26 AM(UTC)
Davesmonaro68
Kyle isn't that head no 2811930
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#14 Posted : Tuesday, 18 March 2008 6:47:19 AM(UTC)
yes thats it
heres all the numbers on head -actually i have 2 heads with same casting numbers but different dates or whatever
heres both -so if anyone can tell me thats great
1st head 2811930 than E181 than 2L
2nd head 2811930 than E311 than 1L
#15 Posted : Tuesday, 18 March 2008 7:09:38 AM(UTC)
head details above
heads are for sale if anyones interested
#16 Posted : Tuesday, 18 March 2008 7:34:35 AM(UTC)
not XU1 or LC GTR
This page was generated in 0.080 seconds.
