2 Pages<12
#21 Posted : Sunday, 16 March 2008 9:47:20 PM(UTC)
Boom, in NSW WB block with injection won't pass ADR's. It's easier to use a complete later engine. What you describe only works in ADR27 and earlier (ie HJ and mid LX backwards).
If we all had th
#22 Posted : Sunday, 16 March 2008 9:47:20 PM(UTC)
Boom, in NSW WB block with injection wont pass ADRs. Its easier to use a complete later engine. What you describe only works in ADR27 and earlier (ie HJ and mid LX backwards).
If we all had the s
BAD WB Offline
#23 Posted : Sunday, 16 March 2008 9:50:07 PM(UTC)
BAD WB
Gen III aka LS1 yeah? Not too sure about the ali block, i was told if it overheats the motor is basically stuffed, were as cast i was told can take a lot more punishment?
boom Offline
#24 Posted : Monday, 17 March 2008 1:27:07 AM(UTC)
boom
yep, sorry byron, i overlooked that bit,
BADWB - the LS1 is fine with the alloy block. there is a GENTT turbo kit that puts out 400-500kW on a stock motor, so the alloy block is pretty hardy. the only time you'd start worrying is if you go 1000hp+.
boom Offline
#25 Posted : Monday, 17 March 2008 1:27:07 AM(UTC)
boom
BADWB - the LS1 is fine with the alloy block. there is a GENTT turbo kit that puts out 400-500kW on a stock motor, so the alloy block is pretty hardy. the only time youd start worrying is if you go 1000hp+.
Guest (8)
2 Pages<12
