Thanks: 1 times Was thanked: 613 time(s) in 580 post(s)
Boom, in NSW WB block with injection won't pass ADR's. It's easier to use a complete later engine. What you describe only works in ADR27 and earlier (ie HJ and mid LX backwards).
_______________________________________________________ If we all had th |
Boom, in NSW WB block with injection wont pass ADRs. Its easier to use a complete later engine. What you describe only works in ADR27 and earlier (ie HJ and mid LX backwards).
_______________________________________________________ If we all had the s |
Gen III aka LS1 yeah? Not too sure about the ali block, i was told if it overheats the motor is basically stuffed, were as cast i was told can take a lot more punishment?
yep, sorry byron, i overlooked that bit,
BADWB - the LS1 is fine with the alloy block. there is a GENTT turbo kit that puts out 400-500kW on a stock motor, so the alloy block is pretty hardy. the only time you'd start worrying is if you go 1000hp+.
BADWB - the LS1 is fine with the alloy block. there is a GENTT turbo kit that puts out 400-500kW on a stock motor, so the alloy block is pretty hardy. the only time youd start worrying is if you go 1000hp+.
