2nd chance prem Offline
#1 Posted : Sunday, 16 March 2008 3:36:05 AM(UTC)
2nd chance prem
Good afternoon all,
I have just registered on this forum, and have been rebuilding a 68 HK Premier for the last 2 years. I have tried to search for an answer to my question on this forum before, but to no avail. My cars trim code is 1217 - 18R, is this 'Buckskin Beige', what is the combo ?
#2 Posted : Sunday, 16 March 2008 3:46:46 AM(UTC)
Was thanked: 613 time(s) in 580 post(s)
1217 is the external paint colour, not sure what it is. 18 is Buckskin Beige, not sure if R is plain vinyl or an insert.
JBM Offline
#3 Posted : Sunday, 16 March 2008 4:25:58 AM(UTC)
JBM
The number on the next 2 lines will be the paint codes, may only have 1 code, as a rough idea what colour do you think the car was originally and was it 2 tone?
James
You only have to be in fr
Davesmonaro68 Offline
#4 Posted : Sunday, 16 March 2008 4:55:28 AM(UTC)
Davesmonaro68
My premier is 1172-18S is buckskin beige with the ranier inserts.
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#5 Posted : Monday, 17 March 2008 4:42:29 AM(UTC)
2nd chance prem
Cheers for the reply, the vehicle details are as follows;
firewall: HK 11540 A
VIN: 80569KL107156
BODY: 80569-1472-A HK Premier - Adelaide
TRIM: 1217 - 18R ? Buckskin Beige
PAINT: 587 - 10064 Inca Gold
TOP: 585 - 9562 Grecian White
Thsi is
#6 Posted : Monday, 17 March 2008 6:50:01 AM(UTC)
1217 is the Holden paint code for Inca Gold with Grecian White roof.
I had a look in my early HK parts catalogue, and it lists 18R as Buckskin Beige Vinyl.
If we all had the same (good) taste, w
JBM Offline
#7 Posted : Monday, 17 March 2008 7:13:20 AM(UTC)
JBM
The Inca Gold is also a metallic colour.
James
#8 Posted : Monday, 17 March 2008 6:49:41 PM(UTC)
2nd chance prem
Happy with that, thankyou for your assistance.
What else can you decipher from the codes provided ?
#9 Posted : Monday, 17 March 2008 7:40:00 PM(UTC)
2nd chance prem
#10 Posted : Monday, 17 March 2008 10:12:13 PM(UTC)
Its the 1472nd HK Premier out of the Elizabeth (Adelaide) plant. Thats about it. HKs are a bit hard to tell much from the numbers, apart from luxury level, paint and trim. You can work out on a Brisbane car if it was manual or auto but not much else.
_
#11 Posted : Monday, 17 March 2008 10:12:13 PM(UTC)
It's the 1472nd HK Premier out of the Elizabeth (Adelaide) plant. That's about it. HK's are a bit hard to tell much from the numbers, apart from luxury level, paint and trim. You can work out on a Brisbane car if it was manual or auto but not much else.
#12 Posted : Monday, 17 March 2008 11:24:33 PM(UTC)
2nd chance prem
Byron,
Thanks mate,
I know it's a relatively early build, as VIN tag is on the sill and larger tag is on the fire wall. Steering box is date coded 10 APRIL 68. There is what appears to be a white code stenciled on the steering column to firewall mo
#13 Posted : Monday, 17 March 2008 11:24:33 PM(UTC)
2nd chance prem
Byron,
Thanks mate,
I know its a relatively early build, as VIN tag is on the sill and larger tag is on the fire wall. Steering box is date coded 10 APRIL 68. There is what appears to be a white code stenciled on the steering column to firewall mou
