3 Pages123>
bundybluedog Offline
#1 Posted : Monday, 17 March 2008 5:59:46 AM(UTC)
bundybluedog
does the 383 or 355 stroked holden engines lose high rpm reliabilty, do they throw a leg out of bed easier is what im asking? what would be the max rpm for one of these engines seeing that all the mods are in place ie: stronger srings and rockers and pushrods ect..
boom Offline
#2 Posted : Monday, 17 March 2008 6:42:17 AM(UTC)
boom
mine is going to go to 6500, that is pretty common with holden strokers. they don't need huge revs to make power.
considering dropping a V8 into the ute instead of the six aye??
If nissan motorsport is nismo, then doesn't that ma
boom Offline
#3 Posted : Monday, 17 March 2008 6:42:17 AM(UTC)
boom
mine is going to go to 6500, that is pretty common with holden strokers. they dont need huge revs to make power.
If nissan motorsport is nismo, then doesnt that make
#4 Posted : Monday, 17 March 2008 6:47:27 AM(UTC)
Holden sold 350 cubers (ie 5.7) factory with factory warranty, so just find the specs for them and they'll tell you how hard they'll go.
If we all had the same (good) taste, who would buy all the
#5 Posted : Monday, 17 March 2008 6:47:27 AM(UTC)
Holden sold 350 cubers (ie 5.7) factory with factory warranty, so just find the specs for them and theyll tell you how hard theyll go.
If we all had the same (good) taste, who would buy all the F
#6 Posted : Monday, 17 March 2008 7:13:10 AM(UTC)
bundybluedog
nah still the 6 for the ute but..... i sold the monaro well if the guy fronts with the cash that is and the misses gets half for the bills hahaha and i get the other half for a car project. the ute will just be my get around car now. looking at buying a l
boom Offline
#7 Posted : Monday, 17 March 2008 7:36:07 AM(UTC)
boom
of course it all depends on the components you use. The holden 350 strokers used the standard A9L holden rods and the harrop crank used is different to the one harrop sells now.
What components are you using? tell us your plans!
#8 Posted : Monday, 17 March 2008 8:07:24 AM(UTC)
bundybluedog
im looking at the come stroker kit probably 355 as its less work to the block new vn alloy heads harrop mainfold, demon race carb and roller cam backed by turbo 350. 400hp would be nice i wanna run easy 11's with engine reliability and drive it on the str
#9 Posted : Monday, 17 March 2008 8:07:24 AM(UTC)
bundybluedog
im looking at the come stroker kit probably 355 as its less work to the block new vn alloy heads harrop mainfold, demon race carb and roller cam backed by turbo 350. 400hp would be nice i wanna run easy 11s with engine reliability and drive it on the stre
boom Offline
#10 Posted : Monday, 17 March 2008 8:38:50 AM(UTC)
boom
O.K, personally, i wouldnt go COME. not because of quality, but because of value. I just don't think that $2000 is good enough for what you're getting. you get:
Crank
Rods
Pistons, rings etc
Bearings,
and THATS IT
the cranks are good, but the eag
Edited by user Monday, 17 March 2008 8:41:10 AM(UTC)  | Reason: Not specified
boom Offline
#11 Posted : Monday, 17 March 2008 8:38:50 AM(UTC)
boom
O.K, personally, i wouldnt go COME. not because of quality, but because of value. I just dont think that $2000 is good enough for what youre getting. you get:
Crank
Rods
Pistons, rings etc
Bearings,
and THATS IT
the cranks are good, but the eagle
#12 Posted : Monday, 17 March 2008 9:44:42 AM(UTC)
bundybluedog
any cheaper better option is the go, is rocket an aussie company or states? are you using a efi block or older style? i thought they were the same but im no guru. do you need to make clearance on the block for 355?
#13 Posted : Monday, 17 March 2008 4:23:02 PM(UTC)
Mid VR onwards have the block already clearanced for the 350 stroker. These blocks have blank pads on the sides instead of 5.0L.
The VT and late VSIII blocks are also already roller cam blocks.
BAD WB Offline
#14 Posted : Monday, 17 March 2008 7:42:38 PM(UTC)
BAD WB
Byron, do these blocks also have the clearence for a come 383 kit?
#15 Posted : Monday, 17 March 2008 10:08:02 PM(UTC)
Theyll fit the COME 350 stroker kit. Not sure about the 377. Ask them. From memory the clearances for the 350/5.7 crank are the same from mid VR onwards.
#16 Posted : Monday, 17 March 2008 10:08:02 PM(UTC)
They'll fit the COME 350 stroker kit. Not sure about the 377. Ask them. From memory the clearances for the 350/5.7 crank are the same from mid VR onwards.
#17 Posted : Monday, 17 March 2008 10:29:37 PM(UTC)
bundybluedog
might be a cheaper and easier way to go chev stroker? they have 4 bolt mains parts are cheaper and more available with more options.
boom Offline
#18 Posted : Tuesday, 18 March 2008 3:34:55 AM(UTC)
boom
it all depends on whether the torana is Pre 75' or not.
Im using an efi block, less corrosion, less chance of problems arising, and it comes with the VN heads.
the 350 stroker kit will only fit if you are using I-beam rods (in late VR onwards). The
boom Offline
#19 Posted : Tuesday, 18 March 2008 3:34:55 AM(UTC)
boom
it all depends on whether the torana is Pre 75 or not.
#20 Posted : Tuesday, 18 March 2008 4:42:18 AM(UTC)
Have been told by a couple of engine builders that the harrop crank is the best for balance and quality,the come crank is known to break the snout under big revs 6000rpm plus,im using a vn 5L with harrop crank and will be getting 300 hp at the rear wheels
Guest (12)
3 Pages123>
This page was generated in 0.100 seconds.
