HOLD ON Offline
#1 Posted : Monday, 17 March 2008 7:47:35 AM(UTC)
HOLD ON
does the lpg converter have to be vertical or can it be mounted on its side
thanks
#2 Posted : Monday, 17 March 2008 8:36:31 AM(UTC)
vertical
HOLD ON Offline
#3 Posted : Monday, 17 March 2008 10:36:15 AM(UTC)
HOLD ON
i ment horizoltal as in flat
peterwmh Offline
#4 Posted : Monday, 17 March 2008 11:41:27 PM(UTC)
peterwmh
Yes has to be vertical and there is a requirement on it's vertical relationship to the mixer too, I think the convertor needs to be slightly lower than the mixer if I remember correctly??
Peter
202 and three on the tree, can't get more Aus
peterwmh Offline
#5 Posted : Monday, 17 March 2008 11:41:27 PM(UTC)
peterwmh
Yes has to be vertical and there is a requirement on its vertical relationship to the mixer too, I think the convertor needs to be slightly lower than the mixer if I remember correctly??
Peter
202 and three on the tree, cant get more Aussi
#6 Posted : Tuesday, 18 March 2008 1:38:51 AM(UTC)
Yes they are meant to be horizontal for better coolant flow. having said that mine is fine mounted vertically and has been that way for 9 years.
Som
#7 Posted : Tuesday, 18 March 2008 10:19:41 AM(UTC)
Yeah I've seen them mounted in all positions and they work ok.
The coolant will flow no matter what position. The liquid gas will flow no matter what position, and the gas gas will be sucked out no matter what position. It does help to mount the converte
#8 Posted : Tuesday, 18 March 2008 10:19:41 AM(UTC)
Yeah Ive seen them mounted in all positions and they work ok.
The coolant will flow no matter what position. The liquid gas will flow no matter what position, and the gas gas will be sucked out no matter what position. It does help to mount the converter
vintageholden Offline
#9 Posted : Tuesday, 18 March 2008 10:30:49 AM(UTC)
vintageholden
thanks ..........i,m doing the same thing...
how far away can the converter be away from the mixer
some say.. if its to far away its hard to start
Edited by user Tuesday, 18 March 2008 10:31:33 AM(UTC)  | Reason: Not specified
Guest (5)
This page was generated in 0.080 seconds.
