WBLJE Offline
#1 Posted : Saturday, 22 March 2008 4:55:06 AM(UTC)
WBLJE
hey all picking up a wb tonner in a couple of weeks and would like to here the sweet sound of a twin pipe v8 out the back.done this conversion ages ago but might need some input.
-need v8 bellhousing
-need v8 input shaft for the m22.is this a straight unbolt pull out front and put in new.??
-can use original engine mounts providing i have the v8 block mount plates.??
-radiator inlet outlet needs to be swapped from side to side.
-no pwr steer easy
-ac just needs bracket
any proven combos on what to do to the 4.2 for a rebuild.i know every one will say yeah a 308 but im not after mega power its a cruiser so i cant justify the extra cost.of course it needs to be a blue motor etc.any help appreciated............cheers
#2 Posted : Saturday, 22 March 2008 5:58:09 AM(UTC)
Was thanked: 613 time(s) in 580 post(s)
Just go and find a complete blue 253 out of a VC-VH or WB. Youll just need a HQ-WB sump for a Commodore engne. Any full cable HZ-WB or VB-VK V8 bellhousing and clutch for will do. I think the 6cyl clutch cable will be fine BUT youll need a late HZ or WB V
Edited by user Saturday, 22 March 2008 6:04:43 AM(UTC)  | Reason: Not specified
#3 Posted : Saturday, 22 March 2008 5:58:09 AM(UTC)
Just go and find a complete blue 253 out of a VC-VH or WB. You'll just need a HQ-WB sump for a Commodore engne. Any full cable HZ-WB or VB-VK V8 bellhousing and clutch for will do. I think the 6cyl clutch cable will be fine BUT you'll need a late HZ or WB
adam PERTH Offline
#4 Posted : Saturday, 22 March 2008 6:22:53 AM(UTC)
adam PERTH
i think that there are a couple of different clutch cables w/respect to clutchfork fulcrum length.
A1 Bogan.
WBLJE Offline
#5 Posted : Saturday, 22 March 2008 6:52:02 AM(UTC)
WBLJE
so are u saying adam the clutch pedal might not have to be changed.i remember something about this when i did my last wb in 92 and i didnt bother changing it used original cable and all.it worked fine but maybe it was adjusted to within a poofteenth of it
#6 Posted : Saturday, 22 March 2008 7:25:16 PM(UTC)
You have to change the pedal. They are different. Just like Commodore where 6 and 8cyl differ. But I think 6 and 8cyl cables are the same (but check 1st)
If we all had the same (good) taste, who
boom Offline
#7 Posted : Saturday, 22 March 2008 9:38:36 PM(UTC)
boom
can you check up that please byron?? i gotta know whether its the clutch pedal i have to change. (or does that all change when i use a toploader/muncie?)
In cubes we trust.
#8 Posted : Sunday, 23 March 2008 7:04:47 AM(UTC)
V8 and 6cyl pedals are different.
WBLJE Offline
#9 Posted : Sunday, 23 March 2008 8:05:03 AM(UTC)
WBLJE
cool thanks fellas.like i said a bloke told me 15 odd yrs ago before i did the last wb conversion.thats before internet/forums etc.just one bloke which im thinking to myself ya noob ya just fu@ked up ill be right.................cheers
boom Offline
#10 Posted : Sunday, 23 March 2008 9:09:26 AM(UTC)
boom
__________________________________________________
Edited by user Sunday, 23 March 2008 9:10:01 AM(UTC)  | Reason: Not specified
#11 Posted : Sunday, 23 March 2008 1:53:48 PM(UTC)
Dont know about Commodore, but the pedal has to be different as more clutch fork movement is required, plus the part number is different. In WB the V8 pedal bolts into a different hole to 6cyl one.
______________________________________________________
#12 Posted : Sunday, 23 March 2008 1:53:48 PM(UTC)
Don't know about Commodore, but the pedal has to be different as more clutch fork movement is required, plus the part number is different. In WB the V8 pedal bolts into a different hole to 6cyl one.
boom Offline
#13 Posted : Sunday, 23 March 2008 7:32:12 PM(UTC)
boom
thanks
In cubes we trust.
#14 Posted : Monday, 24 March 2008 8:25:52 AM(UTC)
WBLJE i have a wb v8 aircon bracket and a condenser
im in brisbane
call me on 0401 704 169 after 11am anyday if interested
#15 Posted : Monday, 24 March 2008 8:25:52 AM(UTC)
i'm in brisbane
This page was generated in 0.124 seconds.
