jimmy64 Offline
#1 Posted : Saturday, 22 March 2008 7:00:18 PM(UTC)
jimmy64
I have been researching past posts and they have been very helpful, however to clarify things a little, my hk has girling front calipers discs approx 12mm thick and I have two spare rotors and discs that are girlock and around 16mm thick, I take from previous posts that the latter are hg ht? and these would be better than the smaller brakes? Also where do i go in SA for new brake lines as the old ones are fairly rusty on outside?
#2 Posted : Sunday, 23 March 2008 1:58:53 AM(UTC)
Hi jimmy64.
All HK & all HT (except GTS350) have 1/2" (12.7mm) disc rotors, while all HG (& HT GTS350) have 5/8" (15.88mm) disc rotors. The thicker rotors are slightly better , but HQ to WB are much better again, if you interested in an upgrade.
Dr
HKPremier Offline
#3 Posted : Sunday, 23 March 2008 4:19:32 AM(UTC)
HKPremier
Jimmy64 i have recently upgraded the brakes on my HK Prem
to HQ discs and am more than stoked if you need to be pointed
in the right direction i can tell you what to do as i think i found every hiccup possible while trying the conversion. But well wort
My Cars
1968 HK Premier 186s Original
1968 HK Premier 307 Chev
hkpremier1968 Offline
#4 Posted : Sunday, 23 March 2008 5:11:41 AM(UTC)
hkpremier1968
Hi, just a quick note about HQ on the front of HK HT HG. There are a few different types of calipers on HQ and some are rather large. We had the problem of the caliper hitting the upper control arms and only letting us turn slightly and made the car hard
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
This page was generated in 0.022 seconds.
