hg_lover Offline
#1 Posted : Sunday, 23 March 2008 4:20:48 AM(UTC)
hg_lover
Hey guys,
Have a HK ute with a 350 chev from a HQ. I know this sump won't fit. The ute has a rack and pinion steering setup so I'm unsure what sump will fit. I've been told maybe a HK chev sump will fit. Anyone had the same situation in the past?
And for that matter with the rack and pinion steering what headers will fit?
Also, it's on straight LPG and I want to replace the old manifold. It has a Rochester on it now....anyone recommend a good spread bore manifold to suit this?
Martin
#2 Posted : Sunday, 23 March 2008 8:46:28 PM(UTC)
Is the rack in front or rear of the x-member? If its front mounted a HQ one should work.
#3 Posted : Sunday, 23 March 2008 8:46:28 PM(UTC)
Is the rack in front or rear of the x-member? If it's front mounted a HQ one should work.
hg_lover Offline
#4 Posted : Monday, 24 March 2008 5:19:21 AM(UTC)
hg_lover
Im not too sure about that, I think it sits pretty much where the drag link used to be. I will try and get some clarification on that or maybe get a pic up soon.
hg_lover Offline
#5 Posted : Monday, 24 March 2008 5:19:21 AM(UTC)
hg_lover
I'm not too sure about that, I think it sits pretty much where the drag link used to be. I will try and get some clarification on that or maybe get a pic up soon.
#6 Posted : Monday, 24 March 2008 8:01:46 AM(UTC)
i have done this swap from steer box to rack in HK-T-G Holdens quite a few times when fitting big blocks and small blocks to these cars. the rack always goes to the front with this type of conversion and sit the eng down lower if you want, you can use a H
hg_lover Offline
#7 Posted : Monday, 24 March 2008 10:05:41 PM(UTC)
hg_lover
How would I sit the engine down lower? Just something with the engine mounts?
As for the sump...sounds good, I suppose Ill try and fit the engine in there first before I go trying to source another sump------ :P
The headers will not interfere with t
hg_lover Offline
#8 Posted : Monday, 24 March 2008 10:05:41 PM(UTC)
hg_lover
As for the sump...sounds good, I suppose I'll try and fit the engine in there first before I go trying to source another sump------ :P
hg_lover Offline
#9 Posted : Tuesday, 25 March 2008 10:30:14 PM(UTC)
hg_lover
The rack and pinion setup is behind the crossmember.
So I guess Im looking at a HK chev sump?
hg_lover Offline
#10 Posted : Tuesday, 25 March 2008 10:30:14 PM(UTC)
hg_lover
So I guess I'm looking at a HK chev sump?
#11 Posted : Tuesday, 25 March 2008 11:01:12 PM(UTC)
Yes. Thats a good start.
#12 Posted : Tuesday, 25 March 2008 11:01:12 PM(UTC)
Yes. That's a good start.
hg_lover Offline
#13 Posted : Wednesday, 26 March 2008 7:15:56 AM(UTC)
hg_lover
Anyone have a HK chev sump for sale?
#14 Posted : Thursday, 27 March 2008 3:19:22 AM(UTC)
I have a new HK-HG High Energy sump with pick-up for $495
In SA, can send anywhere.
0428837490
hg_lover Offline
#15 Posted : Thursday, 27 March 2008 4:44:45 AM(UTC)
hg_lover
Cheers Spooks,
Can you email me the dimensions of the sump Ill have to check for clearance etc with the rack and pinion setup being behind the crossmember. marty02 at hotmail dot com
hg_lover Offline
#16 Posted : Thursday, 27 March 2008 4:44:45 AM(UTC)
hg_lover
Cheers Spooks,
Can you email me the dimensions of the sump I'll have to check for clearance etc with the rack and pinion setup being behind the crossmember. marty02 at hotmail dot com
#17 Posted : Thursday, 27 March 2008 6:04:50 AM(UTC)
what rack conversion is this one??????????
hg_lover Offline
#18 Posted : Thursday, 27 March 2008 10:11:28 AM(UTC)
hg_lover
I am not sure to tell you the truth, I purchased this car as someone elses abandoned project car. His dad sold it for him but I remember him saying a place in Brisbane fitted it all up for him.
Ive called the dad to try and find out exactly what con
hg_lover Offline
#19 Posted : Thursday, 27 March 2008 10:11:28 AM(UTC)
hg_lover
I am not sure to tell you the truth, I purchased this car as someone else's abandoned project car. His dad sold it for him but I remember him saying a place in Brisbane fitted it all up for him.
I've called the dad to try and find out exactly what c
#20 Posted : Saturday, 29 March 2008 8:25:42 AM(UTC)
oh ok, i have heard of a place in Brisbane that do pwr rack conversions, but im not sure of their name, they advertise in one of the mags as well. all the rack conversions ive used mount at the front, but if its at the rear, so be it!!!!!!
