ford351 Offline
#1 Posted : Sunday, 23 March 2008 7:08:45 AM(UTC)
ford351
gday all just want to know how hard it is to convert my au 6cyl to a 8cyl
zd4me
zd4me
#2 Posted : Wednesday, 26 March 2008 2:41:33 AM(UTC)
Simple, buy a crashed V8 AU and bolt the engine, transmission and engine bay wiring harness in and then replace the 6 cylinder ECU with the V8 one. You will have to use the V8 tacho or get your 6 cyl one re calibrated.
#3 Posted : Wednesday, 26 March 2008 7:14:46 AM(UTC)
cheers mate also will the tailshaft match up
#4 Posted : Wednesday, 26 March 2008 7:16:34 AM(UTC)
sorry got the name wrong
ford351 Offline
#5 Posted : Wednesday, 26 March 2008 7:23:55 AM(UTC)
ford351
trying again, i will get there one day. just need to know if the tailshaft
from the six will fit?
zd4me
zd4me
#6 Posted : Wednesday, 26 March 2008 10:51:04 PM(UTC)
Yes the tailshaft and diff are essentially the same. you may find that ALL V8's had abs which will be the only difference in the diff.
Some people say
ford351 Offline
#7 Posted : Friday, 28 March 2008 6:29:03 AM(UTC)
ford351
mine has abs aswell so all is looking good,thanks for your help mate cheers.
zd4me
zd4me
Dmax Offline
#8 Posted : Friday, 28 March 2008 6:45:30 AM(UTC)
Dmax
I know several people who have done this kind of swap and there generally seems to be inherent dramas with computers etc. One option I would be concidering is to chase up an AU XR8. Not only do you get a v8, you also get all the other little things you
648hp Tunnel Rammed 351, It does not get any better
ford351 Offline
#9 Posted : Saturday, 29 March 2008 7:39:42 AM(UTC)
ford351
looks like this project might be a bit of an expensive exercise maybe i will keep the au6 and spend the money on the fairlane instead.thanks for the reply dmax.
zd4me
zd4me
