#1 Posted : Sunday, 23 March 2008 5:59:23 PM(UTC)
G'day, the extractors on my 350, are basicly stuffed, and I'm thinking of going back to cast iron manifolds. Anyone out there got a recomendation on what manifolds would be best?
The 350 is going into a HQ Premier, mostly cruiser. Engine has a Performer RPM and Holley 600 on top. Some porting, and a warmer cam.
G-box will be a TH700, stock converter.
#2 Posted : Sunday, 23 March 2008 8:42:28 PM(UTC)
Was thanked: 613 time(s) in 580 post(s)
Have a look at some block huggers. They are similar to what is on VN 5L engines.
#3 Posted : Monday, 24 March 2008 8:07:49 AM(UTC)
put some pacemaker, PH5310 tri-ys in there, they will bring it to life..easy
jabba Offline
#4 Posted : Tuesday, 25 March 2008 9:46:36 PM(UTC)
jabba
Or the castlemain auto electrics tri-y's. Worked a treat in the 400 powered HQ ute. Just mind the plug boots, as some of the angles / clearances are a bit tight.
Keep the shiny side up, and the greasy side d
jabba Offline
#5 Posted : Tuesday, 25 March 2008 9:46:36 PM(UTC)
jabba
Or the castlemain auto electrics tri-ys. Worked a treat in the 400 powered HQ ute. Just mind the plug boots, as some of the angles / clearances are a bit tight.
