hgkid1 Offline
#1 Posted : Monday, 24 March 2008 7:01:35 PM(UTC)
hgkid1
i am thinking of changing my wagon from hk stud pattern to hq stud pattern. this means swapping out the diff and front breaks with hq-wb units, can anyone tell me anything about this.... how hard will it be to do what will i need to change etc.
is anyone seling an hq-wb wreck in victoria or up albury way? no motor or box needed just a rolling shell preferably v8.
#2 Posted : Monday, 24 March 2008 8:24:04 PM(UTC)
No need to swap out the diff. Just get the axles redrilled and use HQ-WB drums, leaving the HK backing plates. Change to HQ-WB rear wheel cylinders also (bigger bore).
Front discs and calipers bolt straight on, just swap side for side with the calipers
hgkid1 Offline
#3 Posted : Monday, 24 March 2008 8:28:51 PM(UTC)
hgkid1
will i need to upgrade the booster or master cylinders? will i need to re do lines etc?
how much stronger is the v8 rear end than the 6 cylinder one?
bundybluedog Offline
#4 Posted : Monday, 24 March 2008 8:41:48 PM(UTC)
bundybluedog
re drilling the stud pattern is quite easy if you are confident doing so or you will have to pay someone. might be cheaper to do what i did found a 69 camaro diff 10 bolt stronger then HQ and already have hq stud pattern. i bought mine which was 3.08 open
This page was generated in 0.022 seconds.
