Fastlane
Holden Forums
Holden General Discussion
what is the most desirable 10 bolt and how to ID?
This Q has probably been asked numerous times over, but so I don't get ripped off, or rip someone off, what is THE MOST DESIRABLE 10 bolt? Methinks HQ sedan 3.08 LSD.
On date codes, are they different to engine date codes? eg: a diff i have lying about has F211 cast into it. Does this break down to 11 JUN 72? If so why did they change the format?
What are they worth?
Probably early HK 3.36:1 with Eaton LSD centre, followed by HK-HG with cone type centre. Then maybe HQ 350 3.08 or 3.36.
Date codes changed to normal ie DDMMYY mid HQ.
_______________________________________________________ If we all had the same ( |
sorry to go offtopic a bit, is there a way to date a Trimatic/gearbox? mine has a heap of numbers on a small silver plate and a couple lower to the left.
4/76 HJ monaroGTS |
4/76 HJ monaroGTS |
Hi RdS.
Yes, Tri-Matics can be identified by the 2-letter code on the alloy plate on the LH side of the box. Post those letters & I can tell you what its out of.
Dr Terry. |
Hi RdS.
Yes, Tri-Matics can be identified by the 2-letter code on the alloy plate on the LH side of the box. Post those letters & I can tell you what it's out of.
Dr Terry. |
righto, thanks! My gts somehow managed to have its orig engine, so was just curious if the gearbox was too! (massive doubts though, as the engine has done 550,000... not to sure the ol traumatic could keep up.. hehe)
anyway, on that small tag it has a |
4/76 HJ monaroGTS |
dont mean to nag, but any ideas? i probably should have made a seperate thread!
4/76 HJ monaroGTS |
4/76 HJ monaroGTS |
Fastlane
Holden Forums
