Mechatron Offline
#1 Posted : Thursday, 27 March 2008 10:52:59 AM(UTC)
Mechatron
Hi a guy has asked me to help identify if his Monaro is a V8. The hole at B looks wrong (too low) to me for V8 speedo cable - is it supposed to be up at A somewhere? Maybe in the middle of that circle? Thanks for any help, looks to be an Opel car to me.
Edited by user Thursday, 27 March 2008 10:56:10 AM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 27 March 2008 4:18:28 PM(UTC)
Hole B is correct for HK-HG V8 Saginaw or Powerglide. You can just see the blank speedo cable grommet in the 6cyl speedo cable hole through the slot in the brake booster bracket just to the left of the clutch master cylinder blank-off. This is also correc
Edited by user Thursday, 27 March 2008 4:23:47 PM(UTC)  | Reason: Not specified
#3 Posted : Thursday, 27 March 2008 5:31:23 PM(UTC)
The hole near the steering columnis the mechanical clutch hole for M15/M20/M21 6 cylinder. If you have any other combo it has a rubber bung in it. They are advertised on ebay as "Bathurst" rubber bungs.
Warren
#4 Posted : Thursday, 27 March 2008 5:33:12 PM(UTC)
A is for air conditioning.
Warren
#5 Posted : Thursday, 27 March 2008 5:50:28 PM(UTC)
Warren, wrong hole. I meant to one even further right again, where it looks like someone has enlarged one of the column mounting holes.
If we all had the same (good) taste, who would buy all the
Mechatron Offline
#6 Posted : Thursday, 27 March 2008 8:33:28 PM(UTC)
Mechatron
Thanks Warren and Byron,I think he will be pleased to know his car is a V8. Just on the "Bathurst Bung", is it only HK that have this and T and G have no hole there for auto and hydraulic (Sag) clutch?
Edited by user Thursday, 27 March 2008 8:36:25 PM(UTC)  | Reason: Not specified
#7 Posted : Thursday, 27 March 2008 10:08:39 PM(UTC)
That seems to be about right. I've seen plenty of these plates with no hole before, and plenty with. But changes like these don't always happen with model changes.
#8 Posted : Thursday, 27 March 2008 10:08:39 PM(UTC)
That seems to be about right. Ive seen plenty of these plates with no hole before, and plenty with. But changes like these dont always happen with model changes.
Mechatron Offline
#9 Posted : Thursday, 27 March 2008 10:27:09 PM(UTC)
Mechatron
cheers Byron, I just had a look at a HK prem I've got, column auto, and it has no hole either. Seems pretty random. Car looks original and has cantilever booster and ID plate in middle of firewall so I'm assuming it's a fairly early one... Maybe it (hole/
Mechatron Offline
#10 Posted : Thursday, 27 March 2008 10:27:09 PM(UTC)
Mechatron
cheers Byron, I just had a look at a HK prem Ive got, column auto, and it has no hole either. Seems pretty random. Car looks original and has cantilever booster and ID plate in middle of firewall so Im assuming its a fairly early one... Maybe it (hole/no
This page was generated in 0.099 seconds.
