hey im wondering can i bore and stroke my 307chev to the same sizes as a 350chev.
and if this is too expensive would it be easier to buy a 350 short motor and bolt my stuff on.
does it all fit ? manifolds , timing gear ? would the gear drive i have fit a 350 crank ??
any help would be good thanks.
An aussie 307 (ie HK/HT) can normally be bored to 4". This gives you a 327 cube engine. If you use a 350 crank and 350 pistons you get 350 cubes. You could also use a 3.75" stroke crank (basically a 400 crank with mains ground to suit) and suitable piston |
