kanks Offline
#1 Posted : Tuesday, 1 April 2008 6:39:05 PM(UTC)
kanks
i am painting engine bay in black synthetic ennamel what % of thinners should i use thanks
trubluhq Offline
#2 Posted : Tuesday, 1 April 2008 9:46:50 PM(UTC)
trubluhq
If this is plastic paint (ie DULON) its 1:1.5 (paint:thinners) as a good start point. It is better to test it yourself as air pressure and spray guns may differ. The flow at 1:1.5 is thickish. Maybe try 1:1.8 on a spare panel (ex wreckers) to get the flow
peter_flane Offline
#3 Posted : Wednesday, 2 April 2008 6:36:19 AM(UTC)
peter_flane
If it is air dry enamel, depending on the brand, gun tip size, air pressure, temperature and finish required, it can be between 10%-30% added thinner. If it is two part enamel, 10% added would be enough, after adding hardener. If it is acrylic, then 100%
