#1 Posted : Thursday, 3 April 2008 9:29:15 AM(UTC)
Looking for an A9X expert to offer technical info on genuine A9X Rally Wheels. I have seen wheels that have been spot welded (or riveted) and I have recently seen wheels that have been welded externally with the weld runs showing where the rim meets the centers? Which is the correct wheel and how does one decipher the numbers??
Mr.Jones Offline
#2 Posted : Thursday, 3 April 2008 9:50:32 AM(UTC)
Mr.Jones
try the gmh-torana.com forum there are some A9X nuts over there who can answer any questions you may have.
Leroy
Voltaire
#3 Posted : Thursday, 3 April 2008 9:58:58 AM(UTC)
they have a slight more dish then normal GTS wheel and seem to go for around $1000 each.
#4 Posted : Thursday, 3 April 2008 4:12:21 PM(UTC)
I think this is how it goes:
Spot welded rims are early HQ, made in Canada.
L34 rims were made in house by Holden and have no 14x6JJ near the valve.
A9X rims were made by ROH like the rest of the GTS rims.
From memory about 1" deeper in dish, or o
#5 Posted : Thursday, 3 April 2008 6:14:22 PM(UTC)
I have a set of A9X on my Sandman van in holden museum I will go down and have a look and let you know, but I am sure that there are no external welds on the outer face. The value Mikey states may be correct as I have been offered $5000 for the five rims.
#6 Posted : Thursday, 3 April 2008 6:14:50 PM(UTC)
JBM Offline
#7 Posted : Thursday, 3 April 2008 6:54:43 PM(UTC)
JBM
Would you swap the A9X ones for HQ ones?
James
cannon Offline
#8 Posted : Thursday, 3 April 2008 7:13:14 PM(UTC)
cannon
No not really, I have knocked back a $5000 offer for them for the simple reason they look so good on the van, and I also have quite a lot of spare H series rims. I know they are not original but they really set the van off. Once I find out how to put on a
cannon Offline
#9 Posted : Thursday, 3 April 2008 7:15:13 PM(UTC)
cannon
I also should have mentioned I may know of a set of A9X for sale. A local bloke here found a set, I will check if he still has them.
JBM Offline
#10 Posted : Thursday, 3 April 2008 7:17:30 PM(UTC)
JBM
The A9X wheels will give you a narrower track because of the offset, the Torana ones are -1/4" and I think the HQs are +1/2".
James
#11 Posted : Friday, 4 April 2008 12:17:17 AM(UTC)
IOther way around - wider track.
#12 Posted : Friday, 4 April 2008 2:52:05 AM(UTC)
tonner rims are wider than standard hq rims also
hazzard county Offline
#13 Posted : Friday, 4 April 2008 10:45:10 AM(UTC)
hazzard county
theres one on auction at the moment on ebay $1220 cheapppp
#14 Posted : Friday, 4 April 2008 10:45:10 AM(UTC)
hazzard county
there's one on auction at the moment on ebay $1220 cheapppp
#15 Posted : Friday, 4 April 2008 5:50:02 PM(UTC)
cannon Offline
#16 Posted : Friday, 4 April 2008 6:25:45 PM(UTC)
cannon
My god $1225 for 1 rim, Looks like it might be off to the Holden Museum with the jack and wheel brace!!
#17 Posted : Friday, 4 April 2008 7:35:50 PM(UTC)
According to Just Holdens Magazine, Issue 4 Page 32, A9X Rims are identified by the prefix 231 stamped on them (exactly where it does not say).
JBM Offline
#18 Posted : Friday, 4 April 2008 7:37:29 PM(UTC)
JBM
#19 Posted : Friday, 4 April 2008 9:32:56 PM(UTC)
One sold at Auction (and guess which auction folks!!!) 2 days ago for $2,666 (ONLY ONE RIM!!).
You say your confused, James! How do you achieve a greater offset without changing the rim size. Surely these rims must have been manufactured 7" and not 6"
#20 Posted : Friday, 4 April 2008 9:37:48 PM(UTC)
Hey James,
Why dont you describe, if the originals are still on it, the rims on your L34 (i.e. markings, welds & etc)
Guest (12)
This page was generated in 0.238 seconds.
