I was told that puting a polution manifold on pre-polution heads with the blank you put on the polution manifold will presurize the sump to much and make it leak oil. True or False? i have always used pre pollution heads but with edelbrock manifolds. |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
I wont do anything but not having an exhaust crossover. What is going to pressurise the sump? Pollution manifolds are pretty much junk anyway except for the Group III examples. The pre pollution manifold is pretty good, almost as good as a Performer, so w |
I won't do anything but not having an exhaust crossover. What is going to pressurise the sump? Pollution manifolds are pretty much junk anyway except for the Group III examples. The pre pollution manifold is pretty good, almost as good as a Performer, so |
I sold my 2 performer and 2 pre pollution manifolds last year and haveing trouble finding another good pre polution manifold. i can repair them if anyone has one they wanna part with. |
The lc torana has a 253 in it and i have a 3 308 engines in my shed and just slaping together a mild 308 with the parts i have while i build the stroker. i just need a good manifold |
are the manifolds on the pollution (blue) 253s the same as the blue/black 308s?
In cubes we trust.
dont know but the manifolds i have are 308 blue. and 308 hx im never selling anything again it always bites me in the arse later. were the blue 253s 4 barrel? |
dont know but the manifolds i have are 308 blue. and 308 hx im never selling anything again it always bites me in the arse later. were the blue 253's 4 barrel? |
Some are some aren't, VH 253s had a Rotty on them. Cheers, Pete. Old Holdens never die, they just go faster. Edited by user Friday, 4 April 2008 1:47:10 AM(UTC)
| Reason: Not specified |
Cheers, Pete. Old Holdens never die, they just go faster. |
Some are some arent, VH 253s had a Rotty on them. Cheers, Pete. Old Holdens never die, they just go faster. Edited by user Friday, 4 April 2008 1:47:10 AM(UTC)
Yes to both questions. You can use the blue/black valley on the pre-pollution red heads (not pollution red). Just drill a hole in between the other two around the EGR hole and fit a bolt. It will go through the exhaust crossover but it doesnt matter as th |
Yes to both questions. You can use the blue/black valley on the pre-pollution red heads (not pollution red). Just drill a hole in between the other two around the EGR hole and fit a bolt. It will go through the exhaust crossover but it doesn't matter as t |
Cheers, Pete. Old Holdens never die |
Cheers, Pete. Old Holdens never die, |
One may exist. The 308 in a Bedford had a 2 barrel Rochester but I haven't yet confirmed if the heads were blue or red. The engine has a HEI dizzy. I'm still chasing and E, M and S series Bedford parts catalogue to tell for sure.
______________________ |
One may exist. The 308 in a Bedford had a 2 barrel Rochester but I havent yet confirmed if the heads were blue or red. The engine has a HEI dizzy. Im still chasing and E, M and S series Bedford parts catalogue to tell for sure.
________________________ |
Hi Byron.
That's why I worded the answer "- in a Holden". The Bedford heads are Blue & the manifold suits a Rochester 2-Jet, but it's in a Bedford not in a Holden.
Dr Terry |
Hi Byron.
Thats why I worded the answer "- in a Holden". The Bedford heads are Blue & the manifold suits a Rochester 2-Jet, but its in a Bedford not in a Holden.
Dr Terry |
I did realise that you'd said "Holden" when the post came up after the "submit" button. So the heads are definitely blue? I thought this engine first appeared around 1978, that's why I wasn't sure of the blue or red fact. Out of interest, do the Holden c Edited by user Saturday, 5 April 2008 3:06:12 AM(UTC)
I did realise that youd said "Holden" when the post came up after the "submit" button. So the heads are definitely blue? I thought this engine first appeared around 1978, thats why I wasnt sure of the blue or red fact. Out of interest, do the Holden cons Edited by user Saturday, 5 April 2008 3:06:12 AM(UTC)
