#1 Posted : Tuesday, 8 April 2008 6:42:27 AM(UTC)
hi im just about to restore my pride and joy xc sedan. it has a bit of rust that i am going to cut out and weld in pieces. i was wondering what welder to use. i have a stick and a mig welder but im new to this so i don't know which one.
Any help please.
Thank-you
basketcasebear Offline
#2 Posted : Tuesday, 8 April 2008 7:21:08 AM(UTC)
basketcasebear
hey xcjem,
I have tried a little bit of welding, but am not an eggspert,,
but i have seen my mate do it, and he used an oxy?? apparently it can be done with a mig, with a bit of practice?
I tried it, and made a mess of it, big time!!
found it hard to
DOH!!!
6pak Offline
#3 Posted : Tuesday, 8 April 2008 9:17:52 AM(UTC)
6pak
Hi xcjem
I welded up some of the rust in my ZD with a mig. Play around with scrap metal that is the same thickness to get the power and wire feed speed right first. Another trick I picked up is when you cut out the repair patch round off the corners as
www.earlyfalcons.com Offline
#4 Posted : Wednesday, 9 April 2008 8:14:04 AM(UTC)
xcjem, i'm afraid if you need to ask what welder to use, you may not be up to the task, a stick welder will blow a hole straight through the panels. It can be done with a mig but an oxy is most commonly used.
