Ghannah Offline
#1 Posted : Friday, 11 April 2008 10:26:21 PM(UTC)
Ghannah
I am setting up a VC Commodore for gravel rallying - in fact a long distance event in September. My car has a VN series 4.1 rear end. I want to install a VB-VL width rear end with disc brakes, LSD and either 3.55 or 3.78 ratio centre. I need a set up with a strong housing and strong axles. I have been told the VL Turbo rear end with fine spline axles is the best, but is really hard to find. If any one has one I am keen to buy, even if it requires a rebuild. Are there other good ones, such as a VK V8, which meet my criteria?
Greg
Greg
#2 Posted : Friday, 11 April 2008 11:20:44 PM(UTC)
Was thanked: 613 time(s) in 580 post(s)
VB-VK V8 are a Holden Salisbury, like a HQ-WB and ratios can only be had in 2.6, 2.78, 3.08, 3.36, 3.55 or 4.44 (with a very rare A9X only 3.9). VL V8 and turbo are what you want. VL V8 diffs shouldnt be too hard to find. A whole car is only worth $1,000.
#3 Posted : Friday, 11 April 2008 11:20:44 PM(UTC)
VB-VK V8 are a Holden Salisbury, like a HQ-WB and ratios can only be had in 2.6, 2.78, 3.08, 3.36, 3.55 or 4.44 (with a very rare A9X only 3.9). VL V8 and turbo are what you want. VL V8 diffs shouldn't be too hard to find. A whole car is only worth $1,000
#4 Posted : Tuesday, 15 April 2008 12:38:47 AM(UTC)
hi byron what engine type in a vb vk would run a 3.36 or 3.55 diff ?and how do check ratios without pulling them apart oao
#5 Posted : Tuesday, 15 April 2008 6:51:59 AM(UTC)
The big Salisburys only came behind a 304/308 in VB-VK unless it was one of the VB rally cars. In any case I doubt youll find a 3.36 or 3.55 in too many Commodores. Youll probably find it easier to buy a 3.08 or 2.60 example and use the guts out of a HQ-W
#6 Posted : Tuesday, 15 April 2008 6:51:59 AM(UTC)
The big Salisburys only came behind a 304/308 in VB-VK unless it was one of the VB rally cars. In any case I doubt you'll find a 3.36 or 3.55 in too many Commodores. You'll probably find it easier to buy a 3.08 or 2.60 example and use the guts out of a HQ
#7 Posted : Wednesday, 16 April 2008 10:58:51 PM(UTC)
All 3 litre VL's had a 3.45:1 Borg Warner rear end so the ratio is close to what you want. The NA versions used a 25 spline variant and the turbo's used the stronger 28 spline version.
You could fit a VL V8 diff with NA 3.45 gears then you will have
#8 Posted : Wednesday, 16 April 2008 10:58:51 PM(UTC)
All 3 litre VLs had a 3.45:1 Borg Warner rear end so the ratio is close to what you want. The NA versions used a 25 spline variant and the turbos used the stronger 28 spline version.
You could fit a VL V8 diff with NA 3.45 gears then you will have a
