chevman Offline
#1 Posted : Sunday, 13 April 2008 8:08:13 PM(UTC)
chevman
Hey guys, been offerd this combernation and was needing to know how easy/hard it would be to put in a vk! would i need a moderfied sump and crossmember for gearbox and would i need custom made engine mounts? What does it take to hook up speedo temp oilpresure gauges to standard vk dash! Any help/advice would be great
IF YOU WANT MORE INCHES STROKE IT!!!
#2 Posted : Sunday, 13 April 2008 9:10:27 PM(UTC)
Use a VN-VS V6 K-frame (engine X-member) and it becomes a bolt in fit.
You'll need to weld a tab onto the VK crossmember, and adapt it to the gearbox mount.
The computer in anything past VT is a pain, as they use a CAN-BUS type system for the instrume
#3 Posted : Sunday, 13 April 2008 9:10:27 PM(UTC)
Youll need to weld a tab onto the VK crossmember, and adapt it to the gearbox mount.
The computer in anything past VT is a pain, as they use a CAN-BUS type system for the instrumen
chevman Offline
#4 Posted : Monday, 14 April 2008 5:30:02 AM(UTC)
chevman
Thanks mick, not exactly a huge job but think ill give that one a miss!
