Hey guys, been offerd this combernation and was needing to know how easy/hard it would be to put in a vk! would i need a moderfied sump and crossmember for gearbox and would i need custom made engine mounts? What does it take to hook up speedo temp oilpresure gauges to standard vk dash! Any help/advice would be great |
IF YOU WANT MORE INCHES STROKE IT!!! |
Use a VN-VS V6 K-frame (engine X-member) and it becomes a bolt in fit. You'll need to weld a tab onto the VK crossmember, and adapt it to the gearbox mount.
The computer in anything past VT is a pain, as they use a CAN-BUS type system for the instrume |
Use a VN-VS V6 K-frame (engine X-member) and it becomes a bolt in fit. Youll need to weld a tab onto the VK crossmember, and adapt it to the gearbox mount.
The computer in anything past VT is a pain, as they use a CAN-BUS type system for the instrumen |
Thanks mick, not exactly a huge job but think ill give that one a miss! |
