Robbo Offline
#1 Posted : Sunday, 13 April 2008 9:30:42 PM(UTC)
Robbo
Hi All
I have a new base model VZ ute.It is not going to be used for work as such,it will later however tow a single axle caravan.Being a ute it is fitted with bridgestone RE-88 tyres 205-65 on 7" rim's.My wifes VX sedan is fitted with bridgestone ER-30 tyres on the same rim's [ex police vehicle.]My question is am I able to fit a set of the sedan tyre's to my ute,or do I have to stay with ute rated tyre's.
Cheers.
There Is No Replacement For Displacement.
basketcasebear Offline
#2 Posted : Monday, 14 April 2008 12:22:38 AM(UTC)
basketcasebear
well robbo,
i am sure you will have to have rated wheels and tyres on the ute, to be legal,,,but maybe the wheels and tyres on your other car are rated the same??
but i am not an eggspert,
but utes have higher load ratings?
ptpro
some men s
DOH!!!
christoss Offline
#3 Posted : Monday, 14 April 2008 5:58:55 AM(UTC)
christoss
Check your rego, if its registered as a commercial vehicle it must have commercial tyres.
christoss Offline
#4 Posted : Monday, 14 April 2008 5:58:55 AM(UTC)
christoss
Check your rego, if it's registered as a commercial vehicle it must have commercial tyres.
Custom Offline
#5 Posted : Monday, 14 April 2008 8:11:55 AM(UTC)
Custom
The commercial utes such as Rodaygos and Hiluxs etc that are rated as 1 tonne require light commercial tyres.
Showpony utes are only rated at 1 bag of potatoes and can run a standard radial.
Custom Offline
#6 Posted : Monday, 14 April 2008 8:11:55 AM(UTC)
Custom
The commercial utes such as Rodaygo's and Hilux's etc that are rated as 1 tonne require light commercial tyres.
#7 Posted : Monday, 14 April 2008 5:57:39 PM(UTC)
Look at the tyre placard - it will specify minimum load & speed ratings for the tyres you are allowed to run on the vehicle.
A lot of people aim to achieve nothing in l
Robbo Offline
#8 Posted : Tuesday, 15 April 2008 4:04:31 AM(UTC)
Robbo
Thanks for your advice guys.
Cheers.
