#1 Posted : Monday, 14 April 2008 8:27:41 PM(UTC)
Does any know if the bore size of a Holden V8 engine can be sustanciated between 308 vs 253 without pulling off the cylinder head?
Just imagine there is no engine number and the displacement no on the side of the block has been ground-off.
#2 Posted : Monday, 14 April 2008 10:41:45 PM(UTC)
Sorry what I meant was "substantiated"
JBM Offline
#3 Posted : Monday, 14 April 2008 10:52:03 PM(UTC)
JBM
No. The stock bore size and corresponding components are different one to the other. The 308 has a 4" bore and the 253 is 3.625".
James
vintageholden Offline
#4 Posted : Tuesday, 15 April 2008 12:03:32 AM(UTC)
vintageholden
253 is 3.625
same as 202 holden
#5 Posted : Tuesday, 15 April 2008 12:07:26 AM(UTC)
Hi Guys.
I think what SuSA9X wants to know is, how does he tell a 253 from a 308, without removing the head, if the engine number and casting number are not there.
Dr Terry.
JBM Offline
#6 Posted : Tuesday, 15 April 2008 12:20:33 AM(UTC)
JBM
The motors are the same externally. However, an early 253 had a 2 barrel carb and its manual box was usually an M20 rather than an M21, the Trimatic and diff were the same, except in the HK and HG where the 308 had a Salisbury.
Maybe the part nos are d
Edited by user Tuesday, 15 April 2008 12:22:29 AM(UTC)  | Reason: Not specified
boom Offline
#7 Posted : Tuesday, 15 April 2008 5:08:22 AM(UTC)
boom
check the engine number.
In cubes we trust.
#8 Posted : Tuesday, 15 April 2008 6:37:47 AM(UTC)
Was thanked: 613 time(s) in 580 post(s)
He already said it wasn't there.
Very hard call. Look for numbers on the block. Start at the front near the cast date, and post them here.
If we all had the same (good) taste, who would buy all
#9 Posted : Tuesday, 15 April 2008 6:37:47 AM(UTC)
He already said it wasnt there.
If we all had the same (good) taste, who would buy all t
#10 Posted : Tuesday, 15 April 2008 7:02:03 AM(UTC)
Is there a cylinder volume test (i.e. Air or fluid) that can be done to measure displacement or are there collapsible Verniers available which can be inserted through the spark plug hole?
I would have thought, given that these things have been around s
#11 Posted : Tuesday, 15 April 2008 7:11:48 AM(UTC)
CAMS scrutineers would probably have a cc tester (or more accurately a cylinder volume tester). Ive never seen one though.
#12 Posted : Tuesday, 15 April 2008 7:11:48 AM(UTC)
CAMS scrutineers would probably have a cc tester (or more accurately a cylinder volume tester). I've never seen one though.
#13 Posted : Tuesday, 15 April 2008 8:22:44 AM(UTC)
vintageholden
In cubes we trust.
boom Offline
#14 Posted : Tuesday, 15 April 2008 8:54:23 PM(UTC)
boom
sorry didnt read that bit.
In cubes we trust.
Guest (5)
