Browno Offline
#1 Posted : Wednesday, 16 April 2008 4:26:57 AM(UTC)
Browno
G'day, a bloke at work has given me one just wondering if i could get some advice about them and info etc etc he said it was out of a xd or xf its a boarg warner
Drive It Like You Stole It
Drive It Like You Stole It......Drive it like you own it
#2 Posted : Wednesday, 16 April 2008 9:58:33 PM(UTC)
Behind a 6 cyl they are a nice reliable strong box. Even behind a 302 they survive well. The 351 variants had different ratios but I'm not sure if they were stronger or not.
If you have the 4 speed bell housing then it will bolt in place of yo
#3 Posted : Sunday, 22 June 2008 1:23:55 PM(UTC)
ive got a 302 in xd and blown 3single rails.go the t5 with sum minor mods(bellhouseing)etc...
80737k Offline
#4 Posted : Tuesday, 24 June 2008 8:02:47 PM(UTC)
80737k
I'm planning to use a Toploader behind a mild 265 Hemi but the prices they're starting to get has me a little conserned so i'm thinking single rail.
I assume from the above posts that a single rail is up to the task but is there any diffrence to a Valia
Fossil fuels are YUMMY !
#5 Posted : Wednesday, 25 June 2008 12:32:09 AM(UTC)
OK,
A Ford Single rail is nowhere near as strong as a Toploader but does share the same clutch and bellhousing as a small block toploader.
The ford Single rail shares very few parts with the Valiant single rail unfortunately. Firstly the Ford inp
#6 Posted : Wednesday, 25 June 2008 12:36:12 AM(UTC)
Also the last vehicle I drove that had a toploader was a real s h i t due to the crappy external linkages that they are hampered with. The single rail is a much smoother shifting box.
Edited by user Wednesday, 25 June 2008 12:36:44 AM(UTC)  | Reason: Not specified
80737k Offline
#7 Posted : Wednesday, 25 June 2008 7:04:38 AM(UTC)
80737k
Thanks for the info Jim. I have priced a bellhousing for the ford box onto hemi (IIRC $450ish). I think i'm better off doing the Ford box in the long run so will stick to the plan but if when the time comes to buy a box that i gotta pay a huge price for a
Edited by user Wednesday, 25 June 2008 7:06:26 AM(UTC)  | Reason: Not specified
#8 Posted : Wednesday, 25 June 2008 7:12:49 AM(UTC)
I'm not sure about the strength but the 351 single rail has different ratio's to the 6 cyl/302 box.
As for the top loader I think that most of them are the same except the big block versions which have a very large input shaft.
Yes linkages woul
Edited by user Wednesday, 25 June 2008 7:14:38 AM(UTC)  | Reason: Not specified
#9 Posted : Thursday, 26 June 2008 5:17:20 AM(UTC)
G'day,there are at least 2 different shifters for toploaders,one for falcons and one for cortinas.The cortinas shifter is about 4 inchs further forward than the falcons and generally is alot cheaper to buy.It's not horsepower that kills gearboxs but big t
This page was generated in 0.205 seconds.
