Brendan Vp Offline
#1 Posted : Friday, 18 April 2008 6:56:09 AM(UTC)
Brendan Vp
Hi. Im nearly at my witts end trying to solve my problem. i have recently bought my second vp commodore. it runs fine, but it doesnt start very easy when hot( 10 seconds or more of cranking)
This is a list of new components i have added to the car to try and solve it
Plugs
Leads
Coils and Dfi
Temp sensor
Oxygen Sensor
crank angle sensor
harmonic balancer
I have also thougoly cleaned the throttle body and iac pintle( didnt touch any other part just the pintle)
Any Help would be great
Thankyou
Brendan
mmazz30 Offline
#2 Posted : Friday, 18 April 2008 7:47:45 AM(UTC)
mmazz30
Possible leaking injectors...does it blow black smoke when it starts?
Fuel pressure reg can be dicky also.
BrianH Offline
#3 Posted : Friday, 18 April 2008 10:57:25 AM(UTC)
BrianH
The definition in the hard starting section of the factory engine manual is "Engine cranks ok but does not start for a long time". Leaking injectors are mentioned and so is a faulty in tank fuel pump check valve. This will allow the fuel to drain back i
Brendan Vp Offline
#4 Posted : Friday, 18 April 2008 6:13:21 PM(UTC)
Brendan Vp
Thanks but i forgot to add a few things to that list
it has ultrasonically cleaned injectors, a new fuel pump and new fuel regulator. sorry i was very tired when i wrote it all in
Brendan
#5 Posted : Monday, 14 July 2008 1:58:29 PM(UTC)
Hi Brendan just wondering if you now fixed your problem? I have a VX Commodore V6 has exactly the same problem. It is very hard to start when hot. I have replaced injectors, plugs, fuel filter, air filter, it was due for a service but I decided to do thin
#6 Posted : Tuesday, 15 July 2008 5:01:37 AM(UTC)
have you had it on a scan tool? have you had the fuel pressure checked?
where are you located?
#7 Posted : Tuesday, 15 July 2008 5:59:06 AM(UTC)
Try swapping your fuel pump relay for another similar relay e.g. horn? and see if that helps.
#8 Posted : Wednesday, 16 July 2008 8:18:33 AM(UTC)
Hey Thanks guys, I bought a new fuel pump and will change it over the weekend.
#9 Posted : Wednesday, 16 July 2008 8:18:33 AM(UTC)
Hey Thank's guys, I bought a new fuel pump and will change it over the weekend.
peterwmh Offline
#10 Posted : Wednesday, 16 July 2008 8:39:40 PM(UTC)
peterwmh
Have you replaced the fuel filter, I had a VT and when it was cold it started fine as the sediment had settled in the filter, but once it was all stirred up it would cut out at times and would be hard to start hot, could be worth a try.
Peter
202 an
