Is there any difference with a TH400, trimatic crossmember for a HQ
Yes. And sedan/wagon/statesman are different to ute/van/tonner. Best bet is to get a HJ-HZ 308 Statesman one.
Thanks that what I was thinking, it was pulled from a 1 tonner, to fit my monaro
different to those 2 is the T350 crossmember too..... make sure it is a 400 first
He who hesitates, -Masturbates. |
Definitley TH400 box alot shorter then a TH350
If crossmember is shorter it's from a ute/van/tonner which won't fit your sedan. TH400 crossmember has flat strengthening plates across each side as well. Just find someone wrecking a HJ-HZ Statesman pre 1979 and you'll find one.
______________________ |
If crossmember is shorter its from a ute/van/tonner which wont fit your sedan. TH400 crossmember has flat strengthening plates across each side as well. Just find someone wrecking a HJ-HZ Statesman pre 1979 and youll find one.
_________________________ |
I have a spare one if your chacing mate. drop me a email/message.
cheers jason |
Depending where you live, i have one in SA. Can post anywhere. [email protected]
got one in melbs west suburbs (LAVERTON)
looking for an ex ambulance based on the hj/x/z 2 tonner see photo |
and collector of all things ambulance police fire and the odd hq to wb parts |
