basketcasebear Offline
#1 Posted : Tuesday, 22 April 2008 11:03:46 PM(UTC)
basketcasebear
well here we go again,
brainwave bear, changed front lower radiator hose yesterday, only because it had a big split in it,,
anyways, when it was all done, and i was congratulating myself on a job well done,,
to my dismay i noticed a small red wire, going no where??
Bugger!!
after much exploritory inspection, i have come the the conclusion,, that i have absolutely no idea where it goes..?
It is in a 1991 falcon panel van,,4.1 i believe.
I think it is something to do with water temp,, num 1,,,because the temp gauge is not working,
it is red,,has a small black plastic end on it, with a small brass metal clip coming out of the end of it, the metal piece has a small bend in it, and a small hole in the bend..
any help please,
and thankyou already
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
Paul351xb Offline
#2 Posted : Wednesday, 23 April 2008 2:31:57 AM(UTC)
Paul351xb
LOL. Have a look for the temperature sender unit on the block. The wire should plug into the top of it.
#3 Posted : Wednesday, 23 April 2008 2:35:14 AM(UTC)
Yes look around the thermostat housing as I think that it's in the head next to that.
Some people say I am out of shape but they are wrong.....Round i
#4 Posted : Wednesday, 23 April 2008 4:27:44 AM(UTC)
basketcasebear
I had another capitan cook,
and i think the temp sender is under the 2 water heater pipes on the front,??
and i think?? i have broken the brass clip, that the plastic wire doobelacky, slips onto?
and it is all in one piece now?? i think??
if the sen
DOH!!!
Paul351xb Offline
#5 Posted : Wednesday, 23 April 2008 5:07:03 AM(UTC)
Paul351xb
I gotta ask you bear. The wire in question is miles away from the radiator hose you were working on. How the hell did you manage to break it? With my somewhat foggy memory I think there was more than one type of connection available on the sender units
#6 Posted : Wednesday, 23 April 2008 7:33:23 AM(UTC)
basketcasebear
hey paul,
uumm??
I dont think you would be surprised at the things i am able to fook up!!!
fine line between genius, and copey dunt!!!
now I think, the sender unit is not far above the lower radiator hose outlet,, and hidden under the two water heater
DOH!!!
