#1 Posted : Thursday, 24 April 2008 12:04:36 AM(UTC)
My 186 motor in my HG ute has blown up. bummer.
I'm looking at putting a replacement motor in it. I've found a few 202's that look alright. Are there any drama's doing this?
Will my 186 manifold and headers fit straight onto the 202 block?
I have heard that I will have to change the sump and make a few other adjustments, what are they?
Any help will be appreciated.
#2 Posted : Thursday, 24 April 2008 2:15:36 AM(UTC)
Was thanked: 613 time(s) in 580 post(s)
Motors are identical externally (well all but). If the 202 doesnt have a HK-HG sump youll have to fit a HK-HG sump and pickup. But thats about it.
If we all had the same (good) taste, who would b
#3 Posted : Thursday, 24 April 2008 2:15:36 AM(UTC)
Motors are identical externally (well all but). If the 202 doesn't have a HK-HG sump you'll have to fit a HK-HG sump and pickup. But that's about it.
peter_flane Offline
#4 Posted : Thursday, 24 April 2008 4:14:40 AM(UTC)
peter_flane
I went from a 149 to a 161 to a 202 red and the only items I had to change were keeping my sump. I already had a 202 carby and manifold on the 149, so it went along for the ride. There wouldnt be a massive difference between a 186 and 202 carby.
peter_flane Offline
#5 Posted : Thursday, 24 April 2008 4:14:40 AM(UTC)
peter_flane
I went from a 149 to a 161 to a 202 red and the only items I had to change were keeping my sump. I already had a 202 carby and manifold on the 149, so it went along for the ride. There wouldn't be a massive difference between a 186 and 202 carby.
#6 Posted : Thursday, 24 April 2008 4:32:40 AM(UTC)
Forgot - has to be a red 202 to be 100% compatable. Blue and black have a different head and hence different manifold and exhaust.
If we all had the same (good) taste, who would buy all the Fords
#7 Posted : Thursday, 24 April 2008 5:53:13 AM(UTC)
Yeah mate, its gonna be a red one.
Thanks for your advice lads, looks like gonna be a red 202.
#8 Posted : Thursday, 24 April 2008 6:30:32 AM(UTC)
Ive just secured a recond 202 for $300. An old fella was doing it up for his car and apparently something happend to the car and he just wanted to get rid of it. Happy days I hope.
#9 Posted : Thursday, 24 April 2008 6:30:32 AM(UTC)
I've just secured a recon'd 202 for $300. An old fella was doing it up for his car and apparently something happend to the car and he just wanted to get rid of it. Happy days I hope.
HQforme Offline
#10 Posted : Thursday, 24 April 2008 6:45:42 AM(UTC)
HQforme
If theyre both reds, put the 186 head on the 202 bottom end for a bit of extra compression (smaller chambers if i remember). Rebuild it first of course.
I just did my red 202. 40thou over, mild crow cam, ported the head and put in larger valves. It sco
"Silly modern cars"
HQforme Offline
#11 Posted : Thursday, 24 April 2008 6:45:42 AM(UTC)
HQforme
If they're both reds, put the 186 head on the 202 bottom end for a bit of extra compression (smaller chambers if i remember). Rebuild it first of course.
"Silly modern cars"
#12 Posted : Thursday, 24 April 2008 7:21:53 AM(UTC)
186 and 202 have the same chamber size.
HQforme Offline
#13 Posted : Thursday, 24 April 2008 10:00:18 AM(UTC)
HQforme
Ok, cool, so why's the swap so popular? Inlet runners better, different valves?
"Silly modern cars"
HQforme Offline
#14 Posted : Thursday, 24 April 2008 10:00:18 AM(UTC)
HQforme
Ok, cool, so whys the swap so popular? Inlet runners better, different valves?
"Silly modern cars"
boom Offline
#15 Posted : Thursday, 24 April 2008 10:28:43 AM(UTC)
boom
rocker studs instead of bridges, making the rockers adjustable.
the small chamber heads start from 173 IIRC.
In cubes we trust.
#16 Posted : Thursday, 24 April 2008 4:14:18 PM(UTC)
#17 Posted : Thursday, 24 April 2008 4:14:18 PM(UTC)
HQforme Offline
#18 Posted : Friday, 25 April 2008 4:33:42 AM(UTC)
HQforme
Woah, knowing that now, its staggering the amount of people i see who have probably been mislead regarding this issue. Cheers!
Lucky i decided to work my 202 head :-)
"Silly modern cars"
HQforme Offline
#19 Posted : Friday, 25 April 2008 4:33:42 AM(UTC)
HQforme
Woah, knowing that now, it's staggering the amount of people i see who have probably been mislead regarding this issue. Cheers!
"Silly modern cars"
#20 Posted : Friday, 25 April 2008 6:04:10 AM(UTC)
You blokes got any idea of the weight of a 202?
Guest (11)
