HZ-GED Offline
#1 Posted : Friday, 25 April 2008 7:11:39 AM(UTC)
HZ-GED
Hi all;
Have just purchased a HK Prem with a 350 (originally 307) and was wondering if it will need an engineers report to be reigistered in Victoria? The engine hasn't been registered with the car before, and I am unable to source the original 307 (DAMN IT!) Maybe down the track if I can find one I will change it back. However, now it has a rebuilt 350 it would be nice to use. I know the ht/hg came out with the 350, so is this considered an ok swap into a hk given they are effectively the same car?
Your input would be greatly appreciated.
Regards;
Geoff
HZ-GED Offline
#2 Posted : Friday, 25 April 2008 7:19:51 AM(UTC)
HZ-GED
By the way, WHat engine combinations did the HK come out with? And is the original engine it cam with easily identifiable? Can the ID tags let us know?
Again, thanks
Geoff
#3 Posted : Friday, 25 April 2008 7:22:49 AM(UTC)
307 and 327 in HK. If you send me the ID data I can tell you approx what 307 engine number you need. Just tell them its a 327. They use the same block as a 350. But 350 in a HK is not a problem, except to be totally correct you need to run the bigger brak
#4 Posted : Friday, 25 April 2008 7:22:49 AM(UTC)
307 and 327 in HK. If you send me the ID data I can tell you approx what 307 engine number you need. Just tell them it's a 327. They use the same block as a 350. But 350 in a HK is not a problem, except to be totally correct you need to run the bigger bra
HZ-GED Offline
#5 Posted : Friday, 9 May 2008 3:07:30 AM(UTC)
HZ-GED
Hi Byron. thanks for the info. Do you have an e-mail address I can send the info to?
Geoff
#6 Posted : Friday, 9 May 2008 6:46:48 AM(UTC)
look under my profile.
Sandman Offline
#7 Posted : Sunday, 11 May 2008 10:21:37 AM(UTC)
Sandman
327s were only a Monaro option in the HKs weren't they?
Sandman Offline
#8 Posted : Sunday, 11 May 2008 10:21:37 AM(UTC)
Sandman
327s were only a Monaro option in the HKs werent they?
#9 Posted : Monday, 12 May 2008 6:15:10 PM(UTC)
Edited by user Monday, 12 May 2008 6:22:44 PM(UTC)  | Reason: Not specified
#10 Posted : Monday, 12 May 2008 6:15:10 PM(UTC)
#11 Posted : Monday, 12 May 2008 7:39:51 PM(UTC)
What some motor registries do is if the car was engineered for that size engine, then oyu do not need an engineers certificate. So as HK to HG are all engineered the same and the HT had the 350, then you do not need an engineers certificate.
However if
